question about wiring my tach into my 91 crx si
Old Dec 11, 2009 | 05:07 PM
Clash0901's Avatar
Default question about wiring my tach into my 91 crx si
i have a 91 crx si as stated in the title and i have an aftermarket tach by autometer. it's a sport-comp and it says monster under sport-comp.
somebody wired it differently and its weird but there are 4 wires coming out:
red
white
green
black
what do these wire up to? red goes to 12v and black to ?? white? green is ground? idk...
Old Dec 11, 2009 | 05:11 PM
DJYoshaBYD's Avatar
Default Re: question about wiring my tach into my 91 crx si
i can assume that red is CONSTANT 12v, black is ground, white or green can either be the switch to turn the back light on, and the other is signal...
Monster tachs are nice... i had one.. im almost 100% positive that white is for the switch.. wire that to your headlights (well, the switch that turns your head lights off and on), and green is signal, and goes to the green wire on your dizzys plug (the only one with 2 wires).. The tach signal is the thick blue one.. im pretty sure its blue..
Old Dec 11, 2009 | 05:44 PM
Clash0901's Avatar
actually i just opened it up and its not re-wired all the wires i listed are straight from the tach but there are 2 orange and 2 brown wires all cut. they are super small.
Old Dec 11, 2009 | 05:53 PM
DJYoshaBYD's Avatar
ok.. then wire them how i listed.. that should work for you..
Old Dec 11, 2009 | 06:01 PM
jhammond_82's Avatar
Reject Papi
yeah, i think the brown wires are for v8 use.
Old Dec 12, 2009 | 09:24 AM
Clash0901's Avatar
i don't have a thick blue wire.
and can i wire the signal to the back of my cluster so i don't have to fish any wires through my firewall?
Old Dec 12, 2009 | 01:02 PM
Disco Monkey's Avatar
yes you can wire it to the back of the cluster.
Old Dec 12, 2009 | 02:07 PM
DJYoshaBYD's Avatar
yeah.. thats not hard... you can do that
that wire is on the dizzy... if you look at the dizzy, you will see 2 plugs from the harness going into it.. one with HELLA wires, and one with only 2 wires..
The smaller one with 2 wires has 2 thick wires, one black (i think), and one blue.. or green.. its the lighter of the 2 on that plug.. im almost positive its blue, but i looked real quick online and couldnt find any pics..
Oh yeah.. feeding it through the firewall is actually alot easier than tearing the cluster out.. lol.. in my experience, anyway..
hatcht9x
12
Apr 18, 2009 07:49 AM
PINKS
May 15, 2006 08:55 PM
HONDA_TYPE_R
Oct 31, 2004 01:45 PM
LS stretch
Jul 30, 2003 12:41 PM
underpressure02
13
Feb 10, 2003 11:47 AM
