Wiring Heated(4wire) O2 sensor
Old Dec 11, 2009 | 04:55 PM
sgallagher's Avatar
Default Wiring Heated(4wire) O2 sensor
Car: 1990 Civic Hatchback dx, originally auto converted to d16a6 manual, PM6 ECU
I want to install a heated O2 sensor into my car and im not quite sure how to wire it up. I have a 4 wire sensor, wire colors are black, grey, white, white. I figure the white wires are for the heater circuits, black ground and grey signal. I will run the signal to the ecu, ground to ground and I was thinking about running both heaters to some 12v source (I think one of the heater circuits is just a monitor for the sensor and doesn't need to be connected for the heater to work but I figure why not just connect both).
If anyone has any info or knowledge on this please let me know
Thanks
Old Dec 11, 2009 | 05:08 PM
DJYoshaBYD's Avatar
Default Re: Wiring Heated(4wire) O2 sensor
well, you want it hooked up to a 12v source (securely.. solder, shrink wrap, etc) that switches on and off with the car, i could imagine..
Bust out one of the obd1 honda manuals online and look at the schematic on how its hooked up in those cars
Old Dec 11, 2009 | 05:20 PM
sgallagher's Avatar
I know to hook it up to an 12v source controlled by the ignition switch.
Its wired to the ecu on the obd1 vehicles.
Old Dec 11, 2009 | 05:23 PM
DJYoshaBYD's Avatar
ok.. ummm.. what voltage is the wire from the ecu that its hooked up to? you dont want to over-volt it...
if you arent obd1, then why are you changing it? lol
Old Dec 11, 2009 | 05:33 PM
redbull-1's Avatar
For a 4 wire O2 sensor, Black is Signal (+), Grey is Signal (-), and the two whites are heater.
http://www.ngksparkplugs.com/tech_su...wirecolors.asp
http://home.earthlink.net/~jcgebhart/o2sens.html
Old Dec 11, 2009 | 05:35 PM
sgallagher's Avatar
Im not sure of the voltage (but im pretty sure its 12v) as I do not have an vehicle that is OBD1 or manual, If anyone knows for sure please let me know.
I am relocating my O2 sensor downstream in the exhaust behind the engine and I want it to get hot fast, plus I am going to convert to OBD1 eventually just not quite yet.
Old Dec 11, 2009 | 05:38 PM
sgallagher's Avatar
Great! Thank you. That could have been a mistake.
Old Aug 5, 2014 | 08:12 AM
gabrielsousa's Avatar
o2 sensor ground on obd1 pinouts is D22
can i connect the o2 sensor ground on ( A23 or A26 or B2 ) ?
Old Aug 5, 2014 | 09:06 AM
4drEF's Avatar
Keyboard Humorist
Why would you even do that? just hook it up to D22 just like you know you should.
You replied to 5 threads that have been inactive for over a year and none even talk about the issue that you are working on.
Next time consider starting your own thread - just one post that directly addresses your question.
Old Aug 5, 2014 | 09:15 AM
because i converted my pw0 obd0 to obd1
and the extra harness dont have the D22, only have 3 GND ( A23 or A26 or B2 )
SORRY, and thx
Driven
11
Aug 30, 2004 08:35 PM
V3locity
Jul 26, 2004 06:54 AM
Sherm
May 23, 2003 12:47 PM
Soled Out
Jan 6, 2003 04:24 PM
