blinkers and tail lights wont work !!help
Old Dec 11, 2009 | 03:45 PM
slammed ej8's Avatar
Default blinkers and tail lights wont work !!help
when i put my blinkers or hazzard's and then press the brake they stop blicking and when i let go of the brake they start blinking again!!! please help....
Old Dec 11, 2009 | 04:04 PM
Default Re: blinkers and tail lights wont work !!help
any1?
Old Dec 11, 2009 | 04:12 PM
du5t33's Avatar
i wanna say your wiring is off somewhere? look under your dash and see if theres a short.
Old Dec 11, 2009 | 08:49 PM
nopee
Old Dec 11, 2009 | 08:59 PM
Former User's Avatar
I wanna say you have the wrong type of brake light bulb installed. They should be double filament rather than single filament bulbs.
Old Dec 11, 2009 | 09:20 PM
itsnotfast's Avatar
x2
Old Dec 15, 2009 | 10:39 AM
Originally Posted by itsnotfast
x2
how can i know what bulbs are right and wrong ,whats the diffrence...
Old Dec 15, 2009 | 10:59 AM
anymore help?
Old Dec 15, 2009 | 11:40 AM
h2def's Avatar
i had the same problam it was a short in my tail light harness...good luck
Old Dec 15, 2009 | 11:44 AM
what exactly was your problem
Old Dec 15, 2009 | 02:08 PM
h2def's Avatar
same problam u are haveing
Old Dec 15, 2009 | 05:14 PM
well they were working fine untill i changed some burnt bulbs idk man
Old Dec 16, 2009 | 12:20 PM
itsnotfast's Avatar
The bulbs you need a dual filament. You probably have single filament, just go to your local parts store and have them looke them up.
Old Dec 16, 2009 | 01:04 PM
h2def's Avatar
im almost positive you cant put the single filament bulb where a dual would go or vise versa... the socket could also have a short
Old Dec 16, 2009 | 01:08 PM
itsnotfast's Avatar
Yea you could do it, it could short out though.
Old Jan 6, 2010 | 08:56 PM
i changed the harness where the bulbs go and nothing.. anyone else.
Old Jan 6, 2010 | 09:03 PM
You have the wrong bulbs installed.
Old Jan 6, 2010 | 09:06 PM
I changed them around and still nothing .
Old Jan 6, 2010 | 09:07 PM
some one give me exact size for the bulbs so i can buy them tommrow.
Old Jan 6, 2010 | 09:08 PM
Changed what around? Again, you almost surely have the wrong bulbs installed.
Old Jan 6, 2010 | 09:21 PM
ok tmmrw morning i will buy new bulbs if your sure thats the problem.
one again when i press the brake my front headlight corners turn on and so do my rear reverse lights.
Old Jan 6, 2010 | 09:28 PM
You have single filament bulbs installed and you need double filament bulbs.
Old Jan 6, 2010 | 09:29 PM
on the top is single and the botom is dual? how does it go and thanks.
Old Jan 6, 2010 | 09:37 PM
The right and left brake lights need to be double filament bulbs because the same bulb is also a taillight, which is on a separate circuit.
Old Jan 7, 2010 | 02:53 PM
thanks bro . problem fixed.
greenbailey
Honda Civic (2001 - 2005)
Oct 23, 2012 10:05 AM
hulsey
Jul 26, 2011 05:16 PM
smurf357
Jul 20, 2008 02:33 PM
ludesrv
May 27, 2006 09:12 AM
homeboy
Jun 15, 2004 09:42 AM
