99 accord keyless entry
Old Dec 11, 2009 | 02:09 PM
bryfug13's Avatar
Icon6 99 accord keyless entry
trying to find out where the keyless entry module is located on my 99 accord ex. Tried to program a remote using the on board programming and the locks wont cycle. can anyone help. Also the passenger lock actuator i think is bad can that effect the programming?
Old Dec 11, 2009 | 04:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: 99 accord keyless entry
It is attached to the drivers under-dash panel if I remember correctly. 94
Old Dec 11, 2009 | 05:00 PM
bryfug13's Avatar
Im guessing you dont know how many and what color wires go into it? There is about 20 connectors down there.
Old Dec 11, 2009 | 08:48 PM
fcm's Avatar
fcm
Old Fart
Probably a green plug, around 20 pin, module will be bigger then pack of smokes, will probably say something on the module. 94
Old Dec 15, 2009 | 03:54 PM
bryfug13's Avatar
If my passenger door lock actuator is bad will that make it so i cant program the remote since that lock wont cycle?
Old Dec 15, 2009 | 07:16 PM
fcm's Avatar
fcm
Old Fart
No, but are you sure it is the actuator, it could be wiring or connections or the "Door Lock Control Module" itself, [pass. door actuator output not working] and in that case there may be other problems with it that prevent programing a remote. 94
Old Dec 16, 2009 | 01:55 PM
bryfug13's Avatar
I bench tested the actuator and its definetely bad as the for the door lock module the driver side works which would make me think nothing is wrong with it.
breds2k
Jun 7, 2019 04:21 PM
Danny.T
Jul 24, 2011 06:43 AM
Dark_Templar
Jan 1, 2009 06:48 AM
ekcivic9
Apr 3, 2006 09:04 PM
Heat
Oct 9, 2003 03:05 PM
