1996 Accord No dashboard lights - Wont Start
Old Dec 10, 2009 | 08:08 PM
AJ_ashu9uf's Avatar
Default 1996 Accord No dashboard lights - Wont Start
1996 Accord LX 5spd Manual transmission ~150k miles
I was returning from a friend's place, unlocked the car, and put in the keys, pressed clutch, tried to start - all pretty quickly, within a second or two (its freezing/windy outside!).
The dashboard lights came on, as they should, and as the starter was about to kick in, everything went off. No more dashboard lights or cabin light. Central locking works but lights dont.
The car just got new muffler and wheel bearing, and was running real smooth. Had driven it twice earlier in the day. The fuel is almost on empty but it should not affect the battery, which was just fine (though 4 yrs old).
I guess I blew some fuse.
Any suggestions, where to look, and what did I do wrong that I blew the fuse? The car is still at friend's place. I will get a fuse from autozone and try to fix myself else get it towed to a mechanic.
I have to drive it from NY to AZ in two weeks! I was thinking of getting spark plugs etc checked this weekend, but now I am worried.
Please help!
Thanks,
Old Dec 10, 2009 | 08:45 PM
silent1jt's Avatar
Default Re: 1996 Accord No dashboard lights - Wont Start
i dont quite understand your problem but i've come up with 2 things:
1)if just your dashboard lights dont turn on then its the dimmer switch or interior light fuse, i think its in the fusebox inside the hood. if not its under the diverside door panel. check fuses before buying them to get the right amperage if you need them (id recommend checking all fuses to make sure they all work.
2) if your car doesnt turn on at all take your battery to autozone to recharge and see if its still good. put at least a gallon of gas more since your on empty.
if that doesnt work id recommend checking if youre getting a spark from your plugs, check fuel pump. check alternator and starter(both can be checked by autozone for free if you can get the car there.)
do you hear any noise when youre trying to start the car? crank?
Old Dec 11, 2009 | 04:14 AM
spoonfedcrx's Avatar
Ignition switch
Old Dec 11, 2009 | 05:12 AM
AJ_ashu9uf's Avatar
1. no sound, no oil pump, no dashboard ... they were all fine, but went out in an instant.
2. Ignition switch has been a problem on 97-02 models, this was manufactured in 95.
I will check the fuses first, then take it to mechanic for ignition switch.
Old Dec 11, 2009 | 06:44 AM
redbull-1's Avatar
Check the underhood fuses first. You may have a short causing a fuse to blow. Check alternator cables, battery cables, etc.
Old Dec 11, 2009 | 06:56 AM
silent1jt's Avatar
X2 make sure your battery posts are tight.
Old Dec 11, 2009 | 02:34 PM
AJ_ashu9uf's Avatar
Silent1jt
the battery clamp was corroded ..
and i checked everything else before coming to battery!
thanks a ton people!!
Old Dec 12, 2009 | 12:12 AM
silent1jt's Avatar
no prob. strange, i had the same problem today. my car died outta nowhere while i was driving, turns out the ground post was corroded. cleaned it and was back on the road in 3 mins.
Old Dec 13, 2009 | 09:01 AM
gregp09's Avatar
i would say check the battery. its 4 years old. thats quite a bit for a battery, the average battery should last bout 4- 4.5 years. have it tested to see if its still good. plus you said its been cold outside, so that might be a big part of it too. when diagnosing electrical problems, always start at the source and work yourself towards the actual problem ( in this case its the starter and the lights.)
Old Dec 13, 2009 | 03:02 PM
This was also a problem in 96-00 civics, 98-01 crvs, 94-97 accords and in a rare case a handful of oddys.
christine in SB
Jan 21, 2012 03:07 PM
JDM Projects
Jul 26, 2011 06:18 PM
timot13
Apr 1, 2009 03:11 PM
em1woot
Audio / Security / Video
Nov 16, 2007 06:10 PM
egriggs85
Mar 2, 2006 02:49 PM
