Turbo selection for all out K-Series
Old Dec 10, 2009 | 05:37 PM
West Werks's Avatar
Default Turbo selection for all out K-Series
New to FI, need some input on the "best" turbo for an all out K-Series that will be used in a 100yd sand drag dragster. No rules, limits, etc. on the engine/turbo/fuel.
We plan on keeping with the stock 87mm bore but having Scat make us a billet crank, we are going to stuff the biggest stoke we can fit with alum rods.
Thanks
Old Dec 10, 2009 | 08:16 PM
TheShodan's Avatar
Moderator
Default Re: Turbo selection for all out K-Series
There is no "BEST" only best for you.
-Budget for cost
-Style (T3 or T4)
-Size inducer
-Power desired
We don't know really the prupose of a 100yd Sand dragster, you need to be specific based upon the power you want to obtain. Otherwise we can't help.
Old Dec 10, 2009 | 09:48 PM
ScorpionT's Avatar
No limits, something like a 66/67mm will be the best you should consider. 100yards isnt much, and anything larger will be pointless. You could use a 71-72mm, but you wont make full use of it and will be left behind.
Old Dec 11, 2009 | 07:05 AM
2CAMSVTEC's Avatar
precision billet 6765 on a divided t3 flange... quick spool is gonna be the key for only 100yrds...
Old Dec 11, 2009 | 07:24 AM
TheShodan's Avatar
Moderator
These are all viable suggestions, but the OP still needs to state answers to the above to get an informed answer from people.
Old Dec 11, 2009 | 08:09 AM
wickedEG's Avatar
Call NRG TECH or T1!!!
Old Dec 11, 2009 | 09:17 AM
oneoverwrx's Avatar
well we definately know it isnt going to hook, what trans out of curiosity.
If more power is better, which it might be, i would do a 372+nitrous setup, be great for spool and big power. And you said no limits. Im just not sure what kind of power level is useful in sand.
Old Dec 11, 2009 | 09:23 AM
Addicted1's Avatar
You could use a larger turbo, such as a 71-72mm, if you wanted to use nitrous off the launch to get you into boost quicker.
Old Dec 11, 2009 | 09:29 AM
Kevin's Avatar
What fuel, transmission are you gonna run? Spool shouldn't be an issue if you're launching at high rpm and spinning the whole time so long as its geared correctly. You can build a good amount of boost off the line. I'd probably start with something in the 72mm range and run it on alcohol.
Old Dec 11, 2009 | 09:38 AM
E85B18's Avatar
Like said, we need more info.
But im in for this unique set up! I rode in a boosted sand rail with an EJ20 engine. Good times! You'll have to make a build thread
Old Dec 11, 2009 | 09:46 AM
West Werks's Avatar
You are correct, sorry I didn't provide those answers.
-Budget for cost - $2k
-Style (T3 or T4) I am thinking T4
-Size inducer - Not sure, what I need help with
-Power desired - We're hoping to push the 1000hp mark (peak)
Thanks
Old Dec 11, 2009 | 09:49 AM
West Werks's Avatar
The car has a halibrand quick change rear end, were still debating on trans, most likely a B&J 2-Speed.
We already have 1 dragster on our team, it has a Pauter Big Block opposed 4 cyl (VW Style), making 850ish HP on 38lbs, plus a 250 shot on top. We just went out last weekend for the first time in 4 years and ran a career best of 2.90.
Old Dec 11, 2009 | 10:36 AM
92sc61's Avatar
sounds interesting. any vids of that rail or the pass?
Old Dec 11, 2009 | 10:58 AM
ScorpionT's Avatar
The trans and rear end changes everything. A 71-72m will work great, but not many of those in your price range. The S372R would be a good match.
Old Dec 11, 2009 | 11:50 AM
E85B18's Avatar
I just youtubed "Turbo sand drag" and found this haha:
Check out 45 seconds in
http://www.youtube.com/watch?v=RD1jPv_fhUI
Old Dec 11, 2009 | 01:30 PM
TheShodan's Avatar
Moderator
Thanks
Ah, now that you're looking over the 1000hp mark, Most of the 76mm and 80mm inducers would be able to do the job. You'll definately use T4 for this project. $2K is a very reasonable budget. PM me for some options.
Old Dec 11, 2009 | 06:25 PM
Glove's Avatar
30 psi
1baddcivicsi
Apr 21, 2009 11:12 AM
95_red_dc
Apr 18, 2009 08:22 PM
bootlegcivic
Dec 20, 2007 08:33 AM
JDM_rolex
Mar 22, 2006 12:53 AM
Jcant22
Sep 16, 2004 08:48 PM
