quick dizzy question
Old Dec 10, 2009 | 03:55 PM
dmeconitas's Avatar
Icon2 quick dizzy question
I have a dizzy off an 90 crx and put it on my 91 sohc zc, however, this dizzy has five plugs and the harness has 7. Is there a way where I can still use it?
Old Dec 10, 2009 | 04:09 PM
BiG ChOr!Zo's Avatar
Default Re: quick dizzy question
what is the dizzy code...td-01u,td-02u or td-18u...!!!
Old Dec 10, 2009 | 04:12 PM
dmeconitas's Avatar
td-01u
Old Dec 10, 2009 | 04:14 PM
td-01u is for dpfi...you need either a td-02u or td-18u mpfi dizzy from either a 88-91 si or 90-91 civic ex...!!!
DJYoshaBYD's Avatar
what was the setup in your 90? DX or Si?
Old Dec 10, 2009 | 04:15 PM
dmeconitas's Avatar
can I swap the ignitor out of the 01u into the other one? I have a 91 crx hf with obdo pm6 with sohc zc
Old Dec 10, 2009 | 04:18 PM
DJYoshaBYD's Avatar
nope.. you would need the one for that style dizzy, i believe..
Old Dec 10, 2009 | 04:21 PM
dmeconitas's Avatar
dang. I thought all sohc dizzys were in exchangeable
Old Dec 10, 2009 | 04:28 PM
DJYoshaBYD's Avatar
well, when it comes to MPFI, yea.. at least within the same OBD
Old Dec 10, 2009 | 04:32 PM
dmeconitas's Avatar
why do dizzy got to be so damm expensive. I might as well convert to obd1
Old Dec 10, 2009 | 04:33 PM
DJYoshaBYD's Avatar
hahaha.. they are expensive because of all the **** honda decided to shove in to them.. lol
Old Dec 10, 2009 | 04:37 PM
dmeconitas's Avatar
DJYoshaBYD I just noticed your located in Stockton, so I am. You wouldnt happen to have an extra dizzy I can buy or use to make sure its the dizzy.
Old Dec 10, 2009 | 04:43 PM
http://sacramento.craigslist.org/pts/1502351449.html
Old Dec 10, 2009 | 04:46 PM
DJYoshaBYD's Avatar
nope.. lol.. i wish i did.. i THINK i have an ingitor for you, though.. i got boxes of car parts.. PM me and ill shoot you my email.. its my primary means of communication
Old Dec 10, 2009 | 07:17 PM
crx_si-r's Avatar
i have a spare LS dizzy. those internals are interchangable. i also have some modules, but you gotta pick it up in sacramento. you can just have it i dont care
oh, and all 88-91 civic/crx distributors regardless of mpfi or dpfi can swap around the coil and ignition module. the same goes for 90-91 B18's
Old Dec 10, 2009 | 07:24 PM
dmeconitas's Avatar
I would love to take that dizzy off your hand. I commute to Davis everyday, I can pic it up tomorrow. When is the best time for you? Where would you like to meet up. B series and D series dizzys are interchangeable.
Old Dec 11, 2009 | 10:57 PM
dmeconitas's Avatar
I picked up the module form crx_si-r, thanks again. My car still will not start. I also tested the continuity on the tdc/crank/cyl I get 350 ohms and it is suppose to be between 350 and 550. Is the sensor bad? If so, can I just replace that senors or do I need a new dizzy?
Old Dec 11, 2009 | 11:10 PM
crx_si-r's Avatar
Hey bro if you want I can sell you my ls distrbutor. It works fine the only difference between this one and the one you need are the mounting tabs. But you can gut the ls and swap the intervals into your td-01u housing. Lmk if your interested. Only thing missing is the module that I already gave you
Chewy Built !
Apr 26, 2007 08:44 PM
VtecKiDD
Sep 21, 2006 11:49 AM
EFwithS2000taillights
Jun 20, 2006 09:18 PM
mikezcdx
Mar 13, 2006 02:39 PM
18gsir
Mar 12, 2004 07:08 AM
