need help determining whats wrong. 98 Accord
i have a 98 accord sedan with a f23a1 sohc (i think). its def. a sohc. just today it started leaking oil on the timing belt side. oil feedline, crankshaft seals, gasket? what is causing this? ne ideas juz put them up guys. btw its pouring oi!l there shouldnt be that many problems that make it pour oil, right?
Is it a lot of motor oil? If it is, it probably is the balancer shaft oil seal coming out. This was a problem with the 5th generation Accords; but, it happens on some 6th generation Accords like yours. Honda makes a retainer to go over it. It needs to be fixed ASAP if it is that seal; replacing the seal and installing the retainer.
I will post the TSB regarding the 5th gen Accord in a few minutes.
Edit: I noticed you said oil pours out, so this is almost certainly it.
Here is the TSB for the previous generation; however, like I said, it happens on your generation Accord too. This happened to one my friend's 6th gen Accord two months ago and Honda of America wouldn't cover it.
http://www.tegger.com/hondafaq/tsb/accord/x00-073e.pdf
That is the most likely possiblity. I put those retainers on all F series T belt services I do. really cheap insurance. Agree Do not drive your vehicle.
wow thanks for the quick replys guys. At least i know what i am dealing with. so this is def fixable? thanx again for the replys and guide .
what all would/should i replace while doing this job. water pump, timing belt for sure but what gaskets or seals should i order also?
I have a 98 sedan as well. At 97K miles, I purchased a bunch of parts $410. I changed everything and added the retainer as well. I have part numbers and stuff, but I cant figure out how to attach a pdf. What comes to mind - change timing belt, seals, water hoses, water pump, radiator and cap, all belts,O2 sensors, shocks, thermostat, PVC and gromet, distributor rotor cap and rotor....I did a major change. All parts I purchased from hondaautomotiveparts.com. How the heck to I post the part numbers? Call www.hondaautomotiveparts.com for help...the dude there is very helpful.
goodluck
goodluck
well if your taking the valve cover off and everything to get to that you might wanna replace the valve cover gasket , sparkplug tube seals , and timing cover gasket ... u would be able to see if they were leaking at all .. but they are pretty cheap and it wouldnt hurt
khlitoshi
Aug 4, 2018 11:00 PM
osamanazir
Jul 22, 2017 04:56 PM
