Having problems. Squeaking and throttle= check engine light.
Old Dec 10, 2009 | 03:03 PM
AccordLXI509's Avatar
Default Having problems. Squeaking and throttle= check engine light.
I start my 89 lx-i and start to drive today and its squeaking like uh-uh-uh-uh not a contant squeak but like a repetative one. So i turn around and pull in to my drive way the and throw it in meutral and as im about to get out i hear the engine going ruhh ruhh ruhh like im like pressin the throttle then letting off and pressing it again etc. Then the check engine light pops on wtf?? Any ideas
Old Dec 10, 2009 | 03:29 PM
bakerskater11's Avatar
Default Re: Having problems. Squeaking and throttle= check engine light.
good luck bro hope she's fixed soon. Else the White 89 with a red door may not live too much longer
Old Dec 10, 2009 | 04:16 PM
KWayRacing's Avatar
Have you checked what code is stored in the ECM? If you crank the vehicle and open the hood which side of the car squeaks Engine side/ Transmission side? Maybe a distributor bearing seizing? easy to inspect. Remove distributor feel motion of bearing.
Old Dec 10, 2009 | 06:20 PM
Thank you what if it is the bearing seizing then what do i do?
Old Dec 10, 2009 | 07:59 PM
Atreidies's Avatar
Change the distributor. But get the CEL code first. Last thing you wanna do is waste time and money swapping parts that don't fix the problem.
Old Dec 10, 2009 | 09:27 PM
Whats a CEL code
Old Dec 10, 2009 | 09:32 PM
Atreidies's Avatar
CEL=check engine light
Old Dec 10, 2009 | 10:52 PM
heres how to check the CEL codes. This should tell ya what ya need to know Nick.
http://www.3geez.com/forum/showthread.php?t=26342
Old Dec 11, 2009 | 06:09 AM
Thanks guys
KidRuthless
Mar 9, 2014 04:57 PM
AudioFunk
Jul 29, 2013 11:02 AM
BMacls
Mar 18, 2003 08:29 AM
JDM DC2 R
Mar 13, 2003 01:19 AM
