OEM honda b20 headgasket same as Golden Eagle 84mm Headgasket??
Old Dec 10, 2009 | 11:48 AM
95dc2teg's Avatar
Default OEM honda b20 headgasket same as Golden Eagle 84mm Headgasket??
I know it might be a stupid *** question, but I am curious. will a b20 head gasket work on my 84mm GSR head and block? Is there a difference between nonvtec and vtec head gaskets? TIA!
Old Dec 10, 2009 | 01:05 PM
champLSinteg's Avatar
Default Re: OEM honda b20 headgasket same as Golden Eagle 84mm Headgasket??
No it is not the same. Golden Eagle bores out the oem vtec head gasket to 84mm. The B20 head gasket does not have the vtec oil feed holes. Oem B20 for an lsvtec setup but not for a vtec head and block unless you want to feed the head externally.
Old Dec 10, 2009 | 07:23 PM
95dc2teg's Avatar
alright sweet thats what i was wondering. will be going with golden eagle again, thanks!
turbo90a
16
May 15, 2025 08:18 PM
ANNiHiLATORS
Nov 28, 2009 11:35 PM
japanstar_ef9
Jun 11, 2008 08:26 AM
blackcrx16
Feb 28, 2008 04:04 PM
Pandahatch
May 17, 2004 09:26 PM
