4g wagovan rt4wd
Old Sep 2, 2002 | 05:13 PM
altoid's Avatar
Default 4g wagovan rt4wd
I've noticed alot of people don't know too much about this engine tranny combo, I myself am still trying to learn, i've been trying to find a performance torque converter that'll fit in, but they're scarce if any. I found out the converter can take about 170 hp before it ponders the idea of explosion. If anyone has any info on the rt4wd transaxle, i would **** my pants in excitement. I'll keep posting here when i find out stuff, i promise.
Old Sep 3, 2002 | 03:48 AM
civicwagonman's Avatar
Default Re: 4g wagovan rt4wd (altoid)
see if you have a local torque converter rebuilder in your area, they may be able to help.
Old Sep 3, 2002 | 07:24 AM
USDM 4G VTEC's Avatar
i will be peeing my pants if u can put that drivetrain into a EF HB and slap a Turbo ZC in that biach.,.,.. that will be the ultimate autocross HB..... i always wondered of slapiing that AWD into the HB...hmmmmmmmmmm
Old Sep 3, 2002 | 07:54 AM
crxgurlllll's Avatar
the transfer case only transfers when it senses slip and even then it only transfers at the most 20%
Level 10 sells performance torque converters built to your spec.....call them up and tell em wut you want
Old Sep 3, 2002 | 12:03 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: 4g wagovan rt4wd (JDM EF9)
that'll never happen.
too many complications.
Old Sep 3, 2002 | 05:29 PM
Default Re: 4g wagovan rt4wd (two.oh)
actually there was a guy in california that put the 4wd drivetrain in a hatchback. he was running it at the dragstrip. takes some modification, but not impossible. I should know, I turned a 2wd wagon into an 4wd one, and thats not near as easy as it seems. everything is different. I can take off full throttle at a wet rainy intersection without ever spinning a tire. put it in 2wd and can't hardly get going at the same intersection. it does more than 20 percent to the rear wheels. the viscous joint allows 3% slippage and then it locks solid. thats straight from the rt4wd website.
Old Sep 3, 2002 | 05:44 PM
altoid's Avatar
Default Re: 4g wagovan rt4wd (eraser)
never heard of level 10, do you have any info?
The 4wd drive train is already in the car, i've just gotta make it a beast
Old Sep 3, 2002 | 07:24 PM
altoid's Avatar
anyone know who carries high performance axles? I don't want those guys wearing out when i've got a rt4wd wagon making a ferrari look bad (haha, yeah right)
Old Sep 4, 2002 | 10:41 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: 4g wagovan rt4wd (civicwagonman)
that'd be cool, but where did he put the gas tank, exhaust, and how'd he hook the rear suspension up is what i'd like to see.
DCf4i
Aug 6, 2008 01:11 PM
ken_r_mer
May 3, 2006 12:35 PM
b16ahybrid
May 31, 2005 06:29 AM
mYsTeR2
Aug 8, 2002 12:31 AM
