0.4v to tps and map sensor?? help
Old Dec 9, 2009 | 09:45 PM
92hatch!'s Avatar
Default 0.4v to tps and map sensor?? help
i only have 0.4 volts to the map sensor and tps...any ideas? im pretty sure there is supposed to be 5v..not sure..thanks for any help..
Old Dec 9, 2009 | 09:57 PM
92hatch!'s Avatar
Default Re: 0.4v to tps and map sensor?? help
tt
Old Dec 10, 2009 | 02:02 PM
delsolproblems's Avatar
Make sure you are testing the right wires. .4v is about what the output of either should be. Test the TPS with the engine not running and the key in the on position. Test the MAP sensor at idle.
Old Dec 10, 2009 | 02:52 PM
92hatch!'s Avatar
car wont start so its kinda hard to test it at idle..
Old Dec 10, 2009 | 09:12 PM
Keep trying and you'll get it!
Seriously though, the TPS and MAP sensor reference voltages are indeed supposed to be 5v with the key at on and the motor off. If the battery is ok and you're testing the correct wires, I don't know why you'd get such a low voltage. Could be a loose connection somewhere.
California98Civ
27
Feb 11, 2014 01:06 PM
fenix4o9
14
Jan 30, 2013 12:39 AM
AVATAR
Dec 14, 2002 05:14 PM
