turbo inlet size HELP
so i recently turboed my car but the turbo smokes. i took off the oil line and didnt see a oil restrictor. so i tried to match a fitting to it but the threads arent 1/8 npt. it looks almost like a course thread. what other sizes are there on turbos besides 1/8 npt? AN? is there a fitting i could bolt onto the turbo to turn the feed into a 1/8 npt. or can i put the oil restrictor any place before the turbo?
thanks
thanks
take the turbo to a hardware store and see if you can match something up. its gotta be npt threads or maybe something metric. highly doubt that its AN.
also are there bolts for an inlet flange? you could get something like this
he just screwed a 1/8 npt in, stretching the threads. you can see the two different thread when you take the fitting off the turbo. he also welded the turbo to the manifold so alittle hard. full ghetto rig. this is my only car so i cant take off the fitting unless i take off the turbo
it does have bolt holes. thank you that was exactly what i was looking for.
95dc2teg
Aug 15, 2007 05:46 AM
