h&r springs 4gen/5gen?
Old Sep 2, 2002 | 04:20 PM
gringo7718's Avatar
Default h&r springs 4gen/5gen?
could i use my friend's 94-95 h&r springs on my 4 gen accord? i searched and i read that the suspensions are similar. any thoughts are appreciated
Old Sep 2, 2002 | 04:21 PM
Accord94DX's Avatar
Default Re: h&r springs 4gen/5gen? (gringo7718)
i tink so. the rates might be a lil stiffer for your car because the 5th gen is a little tubbier.
Gennady's Avatar
New User
Yes you can.
I love your avatar, but you will catch flack from it from the mods/admins....
Old Sep 2, 2002 | 04:24 PM
Nick M's Avatar
Default Re: h&r springs 4gen/5gen? (Wont be beat)
Go for it.
Old Sep 2, 2002 | 04:53 PM
KTeller8's Avatar
Yes you can.
avatars are a good thing
Old Sep 2, 2002 | 07:05 PM
ArchAngel Sabastian's Avatar
New User
Default Re: h&r springs 4gen/5gen? (KTeller8)
"avatars are a good thing" ...yes indeed
i get my H&R's on the 5th anybody know all what tools imma need? ive forgot from the last time i did it on my teh kord ive got access to everything but a lift at the moment made it kinda easier last time.
[Modified by Sabastian, 10:08 PM 9/2/2002]
Old Sep 3, 2002 | 10:02 AM
greensleeper's Avatar
Default Re: h&r springs 4gen/5gen? (Sabastian)
I have a small right up on doing springs and shocks for a 5th gen. I'll send it to you tonight. Want to take some pictures to go with it?
Old Sep 3, 2002 | 10:48 AM
New User
Default Re: h&r springs 4gen/5gen? (greensleeper)
ill take pic's no prob.
Old Sep 3, 2002 | 11:43 AM
TypeSH's Avatar
as far as i know...
94-95 springs by H&R/Neuspeed/Stock are shorter in height than 90-93/96-97 springs because honda raised the perch height for 94-95 for some odd reason, thus requiring shorter springs. It would probably lower your car more than you expect if you are using struts w/ a 90-93/96-97 perch height.
i quote from an email to neuspeed a while back:
The spring rates are about identical...however, the physical dimensions of the springs are different. For you car, you will need the 55.20.12...if you choose to use the 55.20.11, the car will not lower as the spring is physically taller. For some reason, Honda moved the spring perch up the shock body for 1994-95 facilitating the use of a shorter spring. For 1996-97, they moved the perch back down, facilitating the use of the taller spring we had designed for 90-93 model Accords. The Prelude spring will not work as the spring is physically different.
-JC
http://www.neuspeed.com
[Modified by TypeSH, 8:43 PM 9/3/2002]
Old Sep 3, 2002 | 11:49 AM
Default Re: h&r springs 4gen/5gen? (TypeSH)
vedy vedy indavesting
Old Sep 3, 2002 | 12:08 PM
gringo7718's Avatar
thanks the info is very helpful. what does each set of numbers represent 55.20.11???
Old Sep 3, 2002 | 01:11 PM
TypeSH's Avatar
those are neuspeed's part numbers for their springs.
if you look, H&R has pretty much the exact same product line for the accord... leads me to believe these might be the exact same springs, just remarked H&R/Neuspeed.
GSRnold
Nov 11, 2004 01:43 AM
dj626
Nov 4, 2004 03:45 AM
honda607
Jun 18, 2003 05:00 PM
MechEng
Jun 7, 2003 08:46 AM
