B18C5 in EK Smoke in Intake
Old Dec 9, 2009 | 09:44 AM
iangon's Avatar
Default B18C5 in EK Smoke in Intake
Hey guys - I drove my car last night and it seemed to run fine. I just finished reswapping it from another EK where the motor always ran well. This morning I went out to start it and the car turns over but doesn't catch and run normally.
It has been really cold as well. I thought maybe a clogged fuel filter or clogged injectors? But then I noticed carbon build up in the throttle body after trying to start it a bunch. What would cause smoke to come out of the intake manifold? Is something clogged?
Old Dec 9, 2009 | 10:24 AM
king06's Avatar
Default Re: B18C5 in EK Smoke in Intake
Does it back fire when you try to start it or does it run?
Old Dec 9, 2009 | 02:05 PM
iangon's Avatar
a little - so a friend told me to check the cap and rotor on the distributor. When I did I saw the rotor was corroded prolly from the damp woods I had been living in.. I happened to have a new rotor at home and changed it out. It started and ran after that!
Now I am working on getting my idle to settle at the 800 rpm mark. Is that all just the throttle cable adjustment?
Old Dec 11, 2009 | 12:04 AM
king06's Avatar
If the cable is all the way loose than it may be distributor timing, just loosen it and turn it either way till you find a nice idle.
4g63boost
Oct 20, 2014 01:50 AM
bseriesluver
Oct 28, 2009 02:06 AM
stevew84
May 22, 2008 12:01 PM
