Alternator disconnected but can't remove
Old Dec 9, 2009 | 07:42 AM
sajanisch's Avatar
Default Alternator disconnected but can't remove
I'm not much of a mechanic but thought I could handle this because I've done it on other cars...
Okay, I finally got the belt tension adjuster bolt and through bolts removed (and electrical connections) so the alternator is completely free. But now there is not enough space it seems to remove either going up through the engine or down from the bottom. I have a repair manual that does not say anything about this. Anyone know the easiest way to remove ?
1996 Honda Civic DX
Old Dec 9, 2009 | 07:43 AM
ennohohbee's Avatar
Default Re: Alternator disconnected but can't remove
pretty sure you have to take the driver side wheel off to get to it
Old Dec 9, 2009 | 08:35 AM
sajanisch's Avatar
I already have the driver's side wheel off
there is not room to take it out the side either
Old Dec 9, 2009 | 09:41 AM
owneyboy's Avatar
i took mine out by just pulling it upward
Old Dec 9, 2009 | 09:44 AM
sajanisch's Avatar
wasn't the brake master cylinder in the way ?
(seems to be the main thing in my way)
Old Dec 9, 2009 | 09:57 AM
owneyboy's Avatar
na, i just wiggled it until it got out of the way.and i also put its replacement thru the same way... only problem i ran into was my strut bar/fuel return line
Old Dec 9, 2009 | 10:28 AM
Anon51's Avatar
just remove the brake master from teh brake booster (2 12mm bolts) and move the master to the side while you pull the alternator up.
Old Dec 9, 2009 | 10:37 AM
sajanisch's Avatar
ok, now that sounds easy and will work, but I was worried about brake fluid, etc (draining brake lines), do I need to worry about that ?
thanks, Scott
Old Dec 9, 2009 | 10:40 AM
8VEYBEYB's Avatar
wiggle till its free then up behind the intake mani take it out , mine came out just fine...
Old Dec 9, 2009 | 10:49 AM
Former User's Avatar
The alternator is removed from below. Now you need to remove the splash guard and the alternator lower mounting bracket (has 2 bolts).
Old Dec 9, 2009 | 01:56 PM
sajanisch's Avatar
ok, that sounds like the right approach (removing the bracket)
if I can't get the bolts loose (I had a heck of a time with the tension adjust bolt and the through bolt for the alternator) and I have to remove the master cylinder instead, do I have to worrry about brake fluid running all over or anything like that ?
thanks, Scott
Old Dec 9, 2009 | 01:59 PM
The two bolts securing the lower mounting bracket should break loose with a 14-mm socket on an 18" or 24" breaker bar.
Old Dec 9, 2009 | 04:56 PM
Anon51's Avatar
Not to contradict RonJ cuz he's pretty damn good, but i'v always just taken the brake master bolts off and just pushed it to the side without disconnecting brake lines. comes out like a charm. sorry ron just trying to put in personal experience and quickest way tbh.
Old Dec 9, 2009 | 04:59 PM
No need to apologize. There's always more than one way to skin a cat.
Old Dec 9, 2009 | 06:11 PM
Dokta's Avatar
I removed the bracket and pulled it out from the bottom when I did it.
carlthecrx
21
Nov 11, 2007 03:22 PM
benvroom
Aug 9, 2005 07:33 AM
unknownhero16
Dec 27, 2003 05:41 PM
91 civic
Apr 22, 2003 03:38 PM
'88civic
Nov 3, 2002 06:51 AM
