need a 2nd opinion to my diagnosis (fuel pump not priming, main relay or ign. switch?
Old Dec 9, 2009 | 06:21 AM
acidburn2k2's Avatar
Default need a 2nd opinion to my diagnosis (fuel pump not priming, main relay or ign. switch?
So I am having problems w/ my Sol starting. It is sort of an erratic issue but I did some diagnosing. Yesterday when I went to start my car to go to work it turned but did not start, i noticed the fuel pump wasn't priming. Coming back from work I decided to diagnose the problem, my fuel pump works fine. I have the problem narrowed down to my main relay or possibly my ignition switch. Here is what i base my diagnosis on:
after trying several times, the pump will prime and the car will start. (leads me to believe its the ignition switch starting to go bad)
car does not start w/ remote start either (remote start bypasses ignition switch leading me to believe it is main relay)
when pump finally kicks in and primes, it works everytime afterwards, until the car sits for a while, then we are back to not priming/starting.
I just wanted to know what your opinions are, if I am missing anything? When the fuel pump primes, the car fires right up so I know its a fuel delivery issue and not a spark/air issue. and since I know the fuel pump works, it has to be an electrical issue, just need to pin point the actual issue
thanks in advance
Carlos
Old Dec 9, 2009 | 12:42 PM
Default Re: need a 2nd opinion to my diagnosis (fuel pump not priming, main relay or ign. swi
bump bump, anyone?
Old Dec 9, 2009 | 01:19 PM
CivicSpoon's Avatar
When the car doesn't start, and the fuel pump doesn't prime, are you getting spark?
Old Dec 9, 2009 | 03:06 PM
to be honest, didnt even check, I heard the pump not priming and I ran w/ that
Old Dec 9, 2009 | 03:09 PM
93egSLEEPER's Avatar
check all your grounds. sounds like a main fuel relay to me though.
Dokta's Avatar
Sounds similar to when my pgm-fi relay died.
Old Dec 10, 2009 | 04:51 AM
OK, new info, and this will help the case of a bad relay even more I guess. When I let the car sit for a while (in this case overnight), and I turn the key, the fuel pump does prime, but i have to sit there for about a minute before I hear the relay click and the pump prime, anyone had this problem before?
Old Dec 10, 2009 | 06:25 AM
Former User's Avatar
Clean and tighten the ground on the thermostat housing and resolder the main relay.
crazyimport
Sep 2, 2008 09:22 AM
rsanders21
Oct 30, 2007 10:22 PM
wernhersey
May 30, 2007 03:58 PM
2camsaam
Jul 14, 2003 09:09 AM
fluffy
13
Nov 7, 2002 03:55 PM
