EF 8 or EF 9?
Old Dec 8, 2009 | 06:59 PM
Bracingteam's Avatar
Default EF 8 or EF 9?
I have a 1990 Civic si hatchback. How do I know if it is an ef8 or ef9?
Old Dec 8, 2009 | 07:04 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: EF 8 or EF 9?
If you are in the US then it is going to be neither LMFAO...
Look at your VIN tag and it will have some numbers and letters. Towards the beginning you should see the letter "E" then the letter then number following will make out what your chassis code type is.
Old Dec 8, 2009 | 07:09 PM
2point2's Avatar
They used to be called "4th gen" civic hatches...
Old Dec 8, 2009 | 07:12 PM
Oh ok good to know also I want the bumper with the wrap around signal lights. Does anyone have that? or know where to get one?
Old Dec 8, 2009 | 07:14 PM
I know what a VIN tag looks like Im not a moron, just I had no idea about what the "slang" was for this car
Old Dec 8, 2009 | 07:15 PM
DO IT ON ALL FOURS
... come on now man. Look around a little. I know you are a newb and all... That is actually a JDM front bumper. Modification is required to put it on. IF you do it right you have to chop off your front core support and weld the new one in.
Old Dec 8, 2009 | 07:16 PM
Thats what I figured. and I am a honda newb yes rag on me
Old Dec 8, 2009 | 07:20 PM
DO IT ON ALL FOURS
Get used to it... make sure you make friends with the FAQ and the Search button. It will make your stay at Honda-Tech a much better and more pleasant one.
Most people just state that they own a 1991 CRX Si or something of the sort. Saying you own an ED2 isn't too specific and leaves the mind to wander.
Old Dec 8, 2009 | 07:21 PM
DO IT ON ALL FOURS
OH and BTW a 91' CRX Si is not an ED2 I just was using that as an example.
Old Dec 8, 2009 | 07:24 PM
I typed the question into the faq, and nothing came up, but I dont understand what you have presented me here
Old Dec 8, 2009 | 07:58 PM
.Manny.'s Avatar
Touching My Member
It's an ED7
Old Dec 8, 2009 | 08:17 PM
miguey310's Avatar
ef8 and crx from jap
Old Dec 8, 2009 | 08:20 PM
BiG ChOr!Zo's Avatar
unless your car aint rhd then its neither...!!!
Old Dec 9, 2009 | 10:50 AM
LatnKng's Avatar
Icon3 Re: EF 8 or EF 9?
jajajajaja...new bees...he'll get the hang of it..give him some time..we all do.
Old Dec 9, 2009 | 10:51 AM
LatnKng's Avatar
or just buy the whole set and pieces....wait...he said he has a EF8, or EF9, or whatever thats called..forgot..thought it might have been a rex!!
Old Dec 9, 2009 | 06:42 PM
I have a usdm 1990 si hatch. The only thing jdm about it is the B16 swap.
Old Dec 9, 2009 | 08:10 PM
hatchet_honda's Avatar
i call mine a civic hatchback...
Old Dec 9, 2009 | 08:16 PM
.Manny.'s Avatar
Touching My Member
Originally Posted by .Manny.
It's an ED7
It's an ED7
It's an ED7
why is this still open?
Old Dec 9, 2009 | 11:01 PM
garageEF's Avatar
For real.
Buzz words own us all at some point.
Old Dec 9, 2009 | 11:12 PM
DCRB's Avatar
i call mine ed6...
Old Dec 10, 2009 | 07:32 AM
ef8ef9's Avatar
i might b wrong but i think what this guy was asking is which parts would fit on his car those from an ef8 or an ef9 other thing to point out is that u r gonna have to do a lot of fabrication or modifications to ur ride for example u cannot just intall the jdm bumper without also getting the headlights and the hood to go alone with it
Old Dec 10, 2009 | 08:01 AM
huh
Old Dec 10, 2009 | 10:12 AM
Deetz's Avatar
Crazy Honda Guy
What a lot of pitter patter in this thread
If you have a civic hatch and are looking for the front end from a jdm spec model, the EF9 is the model for parts you are after.
Look to get....
- front bumper with signals
- hood
- headlights
- t bar, not needed but will be easier if you have one
Old Dec 10, 2009 | 10:42 AM
4drEF's Avatar
Keyboard Humorist
This conversion is a lot easier than the EF2 (sedan)
You don't need to change the radiator support for the EF9.
Everything bolts right up.
You will also need the filler that goes between the lights ans bumper (missing from the list in the post above)
The only thing you have to do is a little mod on driver's side bumper support.
There's a "hook" that hangs the bumper on to the frame and it does not fit.
You have to bend it out of the way or cut it off.
fenders swap out easy, but if you can get a conversion kit without them then you can save some money.
The only difference is the side marker hole - just get a template and side markers and cut your USDM fenders.
The lights bolt up and you will just need to re-wire them.
To keep your USDM radiator support you just have to relocate the latch on the hood back a little to get it to line up with the latch mechanism on the radiator support..
Old Dec 10, 2009 | 01:06 PM
4g4dcruisin's Avatar
why the **** should joining an online community result in a "bad experience"? its so lame how certain people on HT think they're all big and bad because they are familiar with Hondas.
there should seriously be a rule against ragging on people and blatantly insulting someone just because they dont have a specialized skill set.
