won't rev past 3k and no CEL
Old Dec 8, 2009 | 03:24 PM
accord2civic2prelude's Avatar
Default won't rev past 3k and no CEL
Running b7 w/z6 head. had a few probs in the beginning but all figured out now. Now the issue is now is that my p28 acts like it is in limp mode, wont rev past 3k. i plugged in my p06 and it ran normally. so i know all plugs and grounds are good. i plugged the p28 into a friends car and it didnt do that. plugged it back into mine and again, wont rev past 3k. could it be that i didnt jump d6 with a4 since its a dx?
Old Dec 8, 2009 | 03:26 PM
Default Re: won't rev past 3k and no CEL
Also...NO CEL's what so ever!!!!!!!!!!
Old Dec 8, 2009 | 03:41 PM
bump.
Old Dec 8, 2009 | 05:08 PM
Ok..jump the service connector and now im gettig code 1(o2 sensor) 1 long flash then 5 seconds and another long flash..on and on like that! but when i put the p06 in, it runs just fine. anybody?
Old Dec 8, 2009 | 07:29 PM
tazeat's Avatar
Bad ECU?
Old Dec 8, 2009 | 07:38 PM
nope. it worked with a friends z6. will a bad o2 sensor make it not rev past 3k?
Old Dec 8, 2009 | 08:16 PM
tazeat's Avatar
You say a long flash then 5 seconds, that would be Code 10. Code 10 is the IAT sensor. Try swapping with a known good one?
Old Dec 8, 2009 | 08:22 PM
EGR95's Avatar
bump im having the same problem.
Old Dec 8, 2009 | 08:25 PM
boostB4beauty's Avatar
no, an O2 sensor will not keep you from revving past 3k.
Are there any wires utilized with your p06 that you don't use with your p28?
Or vice versa?
Old Dec 8, 2009 | 08:30 PM
EGR95's Avatar
Or vice versa?
so the problem with the idle is b/c of the ECU right?...
Old Dec 8, 2009 | 10:09 PM
so 1 long flash then 5 seconds and then a long flash and 5 more seconds over and over is 10(IAT)? cool. but would this cause it to not rev past a certain point?
Old Dec 8, 2009 | 10:48 PM
ok the IAT is located on the back side of the IM right?
Old Dec 8, 2009 | 10:57 PM
ok..once i unplug the IAT and jump the SC, the flashes are the same. so its certain that the IAT is the culprit. so could it be a wire loose somewhere? does the p28 look for that? cause in my z6 manifold, there wasnt a IAT
Old Dec 9, 2009 | 08:36 PM
ok the ecu is chipped with a sst chip so im at the final guess of it being the launch control. i havent tried actually driving it, but i have put it in all gears and it does the same thing. if its launch control, how do i remove it?
Old Dec 9, 2009 | 08:55 PM
Default Re: won't rev past 3k and no CEL.......LAUNCH CONTROL
LAUNCH CONTROL..LAUNCH CONTROL.....FRIGGIN LAUNCH CONTROL!!!!!!!!!!!!! what a headache........................
Old Dec 9, 2009 | 09:16 PM
Corksil's Avatar
if it's the car in your avatar, that's the problem.
registering low oil so rev-limiter kicks in to restrict rpm from damaging motor?
Corksil's Avatar
btw hawaii, rep that ****.
props braddah
Old Dec 9, 2009 | 11:45 PM
yeah the car in my avatar was on Craigslist in georgia..thought it was funny. go muddin in a civic.lol! but yeah she runs like a champ now. only problem now is that my radiator cap is not locking so fluid is bubbling out of it.
91hatchproject
Mar 29, 2010 04:40 PM
ssdelsol
Sep 25, 2009 09:20 PM
4LugR
Jul 28, 2007 09:36 AM
Mini-mEK4
May 31, 2004 06:34 PM
Timmay
Feb 4, 2004 02:34 PM
