Custom Front Motor Mount for H22!!!!
Old Dec 8, 2009 | 03:08 PM
94h22acord's Avatar
Default Custom Front Motor Mount for H22!!!!
Whats up guys, i recently rebuilt my 94 accord coupe from the ground up in the past ten months. I have a JDM built and turboed H22. The front mount was always an issue in the past but i got around it. Now with the new setup im thinkin of making a custom solid front mount.
Does anyone think there would b any problems with making a plate to bolt to the engine block stock mount location and a plate to mount to the stock front mount cross member location and welding a rod or something to connect both plates?
I'm thinking it would be great cause it would be a solid mount which would be good for performance and i could care less about vibration.
Also, the rod mount would give me plenty of room for intercooler piping which is where my issue is.
Right now its all fits fine but i have a full core fluidyne rad and log manifold. The coupler on the compressor side of my turbo is hitting the rad fan when the engine shifts.
Old Dec 8, 2009 | 03:53 PM
jlude90's Avatar
Default Re: Custom Front Motor Mount for H22!!!!
Yeah, it'll be fine. If you're on stock mounts the rest of the way there might be some extra stress on it and you might end up breaking something, but its worth a shot.
Old Dec 9, 2009 | 03:17 PM
autoluder's Avatar
If you run the side and rear motor mounts as solid motor mounts with 70A or harder poly inserts, you dont need to run a front motor mount....fyi..
Old Dec 9, 2009 | 06:18 PM
jlude90's Avatar
I run 80A and am still going to be running a solid front mount.
And polyurethane mounts are solid polyurethane, but they're by no means solid, I get movement out of my 80s
Old Dec 10, 2009 | 07:51 PM
94h22acord's Avatar
yea and i also figured making this custom front mount would be way cheaper than a whole mount kit.
Old Dec 10, 2009 | 09:29 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
You will get maaaad vibration and end up cracking the are around the block where the mount is bolted up to. (ask how I know this ,go ahead, ask)
Old Dec 11, 2009 | 12:12 AM
BDM's Avatar
BDM
I run innovative motor mounts without a front mount without any problems.
Old Dec 11, 2009 | 04:35 PM
minilogoguy18's Avatar
Dcfiver, so it's best when running solid aftermarket mounts (mine are ESP) it's best to just not use the front mount at all? Been wondering about this a lot since I did my swap, I just left the stock front mount in.
Old Dec 12, 2009 | 10:26 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
No, no, any atermarket mount will have some type of give to it. I used a solid steel mount for the front and ended up cracking the block.
Old Dec 13, 2009 | 09:57 AM
withoutlimitslude's Avatar
damn that sucks about your block so would it be better to get the rear side and tranny mounts polyurethane and have the front either not on or stock?
Old Dec 14, 2009 | 02:35 PM
spoolin-4's Avatar
With polyurethane mounts, that front mount is still a must...
I ran the back, side, and tranny polyurethane and My motor still tends to jump around for a bit. Mind you I'm pushing 320whp and am boosted, but I'm going with Innovative solid mounts for next season.
Old Dec 14, 2009 | 08:37 PM
S2Carbonworks's Avatar
Boy, solid mounts are pretty stiff on the ride quality
Old Dec 14, 2009 | 09:17 PM
94h22acord's Avatar
yea im either gona go with the innovative mounts or the explicit speed mounts for my setup
mrbh22
Oct 12, 2009 09:13 AM
95accordh22a
Nov 22, 2006 04:06 PM
Project92Hatch
Oct 11, 2005 11:56 AM
C M S
Dec 14, 2004 08:11 AM
hybrid22l
Jul 12, 2001 04:01 PM
