brakes sound like their grinding?
Old Dec 8, 2009 | 11:36 AM
redrocket_ej1's Avatar
Icon2 brakes sound like their grinding?
the car: 95 civic ex w/ 4 wheel discs and abs. the problem: brakes sound like they are grinding but ALL pads and rotors are good? and the splash shields arent hitting the rotors. it only sounds like its grinding only when i hit the brakes.. im at a loss. any help?
Old Dec 8, 2009 | 11:38 AM
HFP-FA5's Avatar
Default Re: brakes sound like their grinding?
maybe you have small rocks stuck somewhere?.. sounds like your rotors.. double chk everything again to be safe
Old Dec 8, 2009 | 12:28 PM
delsolproblems's Avatar
Did you grease the rails before installing the pads? You may need to get a brake hardware set and replace the rails. Does it only happen while the brake is being depressed and not when the pedal is held down and not moving?
Old Dec 8, 2009 | 12:30 PM
93egSLEEPER's Avatar
sounds like they need to be taken aparts and "de-squeaked". you should use to pad silencer and make sure you lube the rails where the pads sit in the caliper. brake dust build up can also cause sounds while braking. what they new pads and rotors or what?
Old Dec 8, 2009 | 01:03 PM
the pads are about 2 months old, and the rotors were turned when i put the pads on.. i will try to take it apart and grease the guides and see if it helps..
Old Dec 9, 2009 | 11:22 AM
nice!! it worked, greased the guides and no noise now.. didnt think that would've made it sound like the brakes were grinding?!? thanks guys
Old Dec 9, 2009 | 04:18 PM
David12's Avatar
silglide ftw!
kaivorth
Honda Civic (2001 - 2005)
Jun 1, 2015 07:33 PM
k_lude
Oct 4, 2006 09:39 PM
fergs96integra
Jan 2, 2006 05:46 AM
Dogginator
10
Sep 1, 2005 09:09 PM
ernald711
Mar 18, 2003 05:38 PM
