Throttle Position Sensor???
Old Dec 8, 2009 | 07:55 AM
toolbox21's Avatar
Default Throttle Position Sensor???
Got A 91 CRX HF Having TPS Problems, Ive Tried Using Multiple Sensors And When I Try To Ome Them Out Wit The Omes Meter I Cant Get It In Spec, I Know Closed Throttle Is .45-.5 And Wide Open Is 4.5, Now I Can Get Closed Throttle In Spec Then MY Wide Open Is 5.1, The I Got My Wide Open In Spec And My Closed Throttle Is Like .1-.2 Its Retarded Any Ideas In What My Problem Is, TB Maybe???
Old Dec 8, 2009 | 04:59 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Throttle Position Sensor???
I think your problem is you are using the "OME" meter and not the "OHM" meter... LOL
You want the closed position to read .5v give or take some and the WOT position to read 4.88v give or take some. Seems like it all looks good to me even if your WOT does read that anyways. You will not be able to actually achieve WOT and have the ECU read 5.1v because you are limited mechanically...
DerekHollister
Mar 25, 2016 04:42 PM
UKintegra
Jun 8, 2011 12:32 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
GsRwHiTe
Mar 22, 2004 03:08 PM
