New here
Old Dec 8, 2009 | 06:24 AM
88JDMmade's Avatar
Default New here
Hey everyone, I just joined recently, my name is Casey. I'm turning nineteen in january and I just picked up one of my many dream cars. last weekend I purchased an 88 CRX HF from a friend of mine for only $100.00. I'm pretty excited to get some work done on it. It still has the stock D15B6 and a 5 speed trans. this is my project car which I'm planing out to have all the motor work and some of the body work finished by the fourth of july next year. I also picked up an 89 CRX Si Shell which I'm planning to use alot of parts from.
I'm not sure what I should be doing to make this car what I want it yet.. so I came here in hopes for some help to find a few ideas.
I'll post some pics of it tonight.
Old Dec 8, 2009 | 06:40 AM
Aftermath_Hatch's Avatar
Default Re: New here
What's up Casey welcome to Honda-Tech hope we can help you here and good luck with the build!
Old Dec 8, 2009 | 07:34 AM
88JDMmade's Avatar
thanks. I'll try to get a few pictures up tonight and ill start a build thread eventually once things move along.. and more money can come in. I'm in college right now so I'm kinda low on cash until the holiday break when I'm working full-time for a bit.
Old Dec 11, 2009 | 06:27 AM
88JDMmade's Avatar
new update. I'll be swapping the D15b6 by tax return time. I'm putting in a B16A1. we are currently getting ahold of the motor and trans. then we will need the ecu and wiring still.. any help on locating these would be great. thanks.
Old Dec 11, 2009 | 06:55 AM
guitarguru87's Avatar
ECU - ebay, junkyard, craigslist, etc.
Wiring - Use the wiring harness that came with your car, get some extra wire and a soldering gun, go to town.
You also need several other things to make this swap work, check the FAQs.
Old Dec 11, 2009 | 10:43 AM
KINGVEM^^ED6's Avatar
Crx for 100 bux but y not build the si instead of the hf? Bump for pics of both
Old Dec 11, 2009 | 10:48 AM
Syper's Avatar
lol yea I was thinking the same!
PICS!!!!!!!!!!!
Old Dec 11, 2009 | 10:54 AM
crx_si-r's Avatar
or build both
Old Dec 11, 2009 | 11:11 AM
C_R_X_V_T_E_C's Avatar
88 hf is the lightest crx made. hella potential.
check these specs:
88HF - 1819
88DX - 1922
88Si - 2017
90HF - 1967
90DX - 2103
90Si - 2174
Old Dec 11, 2009 | 11:17 AM
Simkin314's Avatar
As guitarguru87 said, ECU - ebay, junkyard, craigslist, etc. If you don't want to do the rewiring yourself, Rywire (<link) seems to be a solid place for wire conversions.
Old Dec 11, 2009 | 03:02 PM
91civisedaner's Avatar
If i was you i'd keep the hf stock and get 50-60 mpgs so you can save some money to put in to the si.
Old Dec 11, 2009 | 05:50 PM
jhammond_82's Avatar
Reject Papi
yeah, i'm liking the keep the one stock idea. it may not be the fastest car around, but good gas mileage makes up in that area.
Old Dec 12, 2009 | 12:30 PM
Build both!!!
Old Dec 12, 2009 | 01:10 PM
crawfo661's Avatar
if your goin b-series u'll need to get axles, the ecu, wiring, engine and trans mounts, shift linkage, and prolly a few other odd ball things that always pop up. Get the ecu from the car your getting the motor out of, this makes things a lot easier, and if you want the swap to be clean go to rywire for the wiring, you may be able to do it yourself but this will save you headaches and looks great, hasport makes your mounts and linkage, shop around on here and other sites usually you can find that stuff used and cheaper, there are alot of people that have done this on here, use the search function for info, don't over post questions that have already been answered on here, good luck
Crx_JDMWhore
20
Jan 11, 2012 07:51 AM
lilbill_ed8
Appearance Build Threads
30
Nov 14, 2008 07:38 AM
CrX_RiDInG
Jul 24, 2006 05:36 PM
Dj^BaNNeD
29
Aug 18, 2005 02:06 PM
Jepeezy
Feb 21, 2003 05:12 PM
