injectors????
Old Dec 7, 2009 | 10:40 PM
lantus915's Avatar
Default injectors????
Today i went out and unbolted everything to get the head off completely but when i pulled the fuel rail the injectors were REALLY dirty looked like they were covered in dirt or mud or something do you guys think this may be the cause of my problems ( overheating, smoking exhaust) and not the head gasket?
Old Dec 7, 2009 | 10:53 PM
Vagitarian's Avatar
Default Re: injectors????
Where the fuel sprays was dirty?? Or just the exposed part of the injector was dirty?? If the exterior was the only thing that was dirty, then that wouldnt make a difference. If the pindle area looked dirty, then yeah that would cause some problems.
Old Dec 7, 2009 | 11:03 PM
.Manny.'s Avatar
Touching My Member
Have you performed a Leak Down Test to determine the health of the motor?
Old Dec 7, 2009 | 11:18 PM
lantus915's Avatar
nope
the pin part which is inside of the fuel rail.
Old Dec 7, 2009 | 11:20 PM
Vagitarian's Avatar
That should be clean enough to eat off of, you def have other problems aside from HG, rubber seals around the injectors were all seated properly?
Old Dec 7, 2009 | 11:30 PM
lantus915's Avatar
i dont know it looked like it, i just bought the car dont know its history. it over heats and smokes mildly. i thought it was the head gasket started unbolting everything to pull out the head, then i pulled the fuel rail and the injectors were DIRRRRRRRRTTTTTYYY so i was wondering, could this be the issue or should i keep going and change the head gasket?
Old Dec 7, 2009 | 11:32 PM
Vagitarian's Avatar
Pull the valve cover, no coolant/oil mixture then Id avoid pulling it, if theres coolant in the oil then pull it
Old Dec 8, 2009 | 05:42 AM
jhammond_82's Avatar
Reject Papi
most stock injectors that i have taken out, or replaced had gunk all around them. they almost look burnt? i usually just spray them with tb cleaner and use an old toothbrush to clean the gunk off of them so they seal better and look a little nicer.
Old Dec 8, 2009 | 09:31 AM
lantus915's Avatar
so should i pull the head and do the gasket or just clean the injectors?
Old Dec 8, 2009 | 10:00 AM
.Manny.'s Avatar
Touching My Member
LEAK DOWN TEST!!! Don't just pull **** off because you suspect. Test to determine if the head gasket is blown
mw011i
Jul 18, 2008 05:06 AM
full Circling
Oct 16, 2006 12:01 PM
ThePro
Jun 16, 2005 08:58 PM
7thGear
May 20, 2004 06:37 PM
falcongsr
Mar 11, 2002 09:12 PM
