Ek wont turn on !!!
Old Dec 7, 2009 | 08:05 PM
SingleCammer's Avatar
Icon3 Ek wont turn on !!!
I was being dumb and connected a Throttle Position Sensor wire
to one of my Idle Air Control wire and the car made a weird noise
and didnt start up ... i put everything back to how it was and it still doesnt
turn on only makes a weird winddd noise
Old Dec 7, 2009 | 08:12 PM
Former User's Avatar
Default Re: Ek wont turn on !!!
I assume that the starter cranks the engine with the key turned to ON(III) but the engine doesn't start, right?
The concern is that you may have fried the ECU. Does the CEL remain on when the key is turned to ON(II)? If so, jump the service connector to pull the codes. Also check whether 15A hood fuse 44 (ECU/main relay) is blown.
Old Dec 7, 2009 | 08:49 PM
my check engines was on FTPS so idk if this
problem triggerd another problem ... i have a spare ecu i
hooked up and still nothing...i jumped the starter but nothing
this starter makes a little noise then a winding noise..when i connected the
2 wires together something mustv burned cuz the car just started working
...thank you for replying
Old Dec 7, 2009 | 09:04 PM
itsnotfast's Avatar
Try jumping from your battery to the starter see if it turns then. If not, bad starter. If it works check fuses/relays for the starter. I don't know how your wiring issue would have messed something like that up but it's worth a shot.
Old Dec 7, 2009 | 11:22 PM
Coolero's Avatar
you mixed up some sensers
Old Dec 8, 2009 | 05:41 AM
The car ran perfectly until i decided to be dumb and mess with the sensor wires..I tried jumping the car from the starter and it still didnt turn on.. i dont know how messing with the wires coulda broke the starter
Old Dec 8, 2009 | 06:35 AM
itsnotfast's Avatar
Jump from the battery to the starter. See what happens then.
Old Dec 8, 2009 | 11:44 AM
ok now the starter cranks but really slow and the car dies slowly
Old Dec 8, 2009 | 03:08 PM
bump
RHD_EK9
16
Dec 26, 2011 07:10 AM
5exy_Ek
May 8, 2011 03:21 PM
Seedless DC2
Honda Civic (2006 - 2015)
Oct 28, 2009 03:58 PM
laziebun
Apr 24, 2008 11:10 AM
incubus
23
Mar 14, 2004 07:31 AM
