fuel pump not priming????car not starting...
Old Dec 7, 2009 | 03:37 PM
92hatch!'s Avatar
Default fuel pump not priming????car not starting...
i replaced the=battery,alternator,fuel filter,alternator belt,main relay.
the check engine light is on...but thats for other things like o2 sensor and what not. ussually when i turn the key the fuel pump primes..the the check engine light turns off then when the car starts it turns back on..but now it doesnt do anything no fuel pump nothin...i feel the relay click...but nothin..
please help this is my daily driven car to school
its a 1992 civic hatchback dx. with a b18c5 swap...and a j.k tuning p28 with type-r base map
Old Dec 7, 2009 | 05:26 PM
delsolproblems's Avatar
Default Re: fuel pump not priming????car not starting...
You can check the fuses and then test the pump to see if it is getting power.
Old Dec 7, 2009 | 05:59 PM
92hatch!'s Avatar
it did blow a fuse once and we replaced it and it worked...but we checked the same fuse this time and its fine...
Old Dec 7, 2009 | 06:02 PM
92hatch!'s Avatar
is it possible my new relay went bad also...i dont think so...omg i can not find the problem...
Old Dec 7, 2009 | 06:11 PM
Take the gas cap off and have an assistant turn the key to on while you listen with your ear next to the filler opening. If it's quiet, you'll be able to hear a working pump priming. Try to use this method for checking if it is priming throughout the diagnostic process. Check for voltage at the pump and if there is none, work your way back towards the battery.
Old Dec 7, 2009 | 06:16 PM
92hatch!'s Avatar
i can usually tell if it primes...its loud..
Old Dec 7, 2009 | 06:21 PM
Good, pumps can get pretty quiet when they're old and I wanted to make sure that wasn't an issue.
Old Dec 7, 2009 | 06:29 PM
92hatch!'s Avatar
but i can take the main relay apart and press on the tab to get the fuel pump to turn on or whatever but it still doesnt start cause it doesnt really prime and just makes the same sound...
Old Dec 7, 2009 | 07:33 PM
fcm's Avatar
fcm
Old Fart
There are 2 relays in the PGM-FI Main Relay, the fuel injector relay, [supplies 12V+ to the injectors and a few other things] and the fuel pump relay, [supplies power to the fuel pump].
The "few other things" are the ECU, some engine sensors/valves and it supplies the 12V+ to one side of the fuel pump relays coil, there are 3 diff. fuses for the PGM-FI Main relay, one is hot at all times, [input power for injector relay] one is hot in run and start. [power for one side of injector relays coil and input power for fuel pump power] there is also a hot in start only fuse, [power "stabilizer" during start for one side of fuel pump relays coil].
You say you can hear the relay "click" but the fuel pump is not turning on, but you can hold the contacts, [tab] closed and the pump does run but car will not start, is that correct?
If so, answer this, with the cover off the PGM-FI Main Relay and still plugged in, when you turn on the ign. does the relay "click" but the fuel pump does not prime until you press the tab?
If so, the injector relays contacts are bad or the hot at all times fuse is bad, the "click" would be the injector relay energizing, [turning on] because the hot in run and start fuse is good and power is getting to the relays coil, no power is getting to the fuel pump relays coil so it is not energizing, we know this because if you close the relay manually, [press on tab] the pump works, we already know the hot in run and start fuse is good because it turns on the injector relay and the pump works when pump relay is closed manually, the car will not start even if pump is running because there is no output from the injector relay, [no power to ECU, injectors or engine sensor/valves.
That only leaves the injector relay or the hot at all times fuse, to confirm/eliminate hot at all times fuse by checking for power at one of the leads at the PGM-FI Main Relay plug, [maybe yellow/white or black/white], if no hot at all times power, replace blown fuse, if there is a hot at all times power, [and relay "clicks" when ign. turned on] replace the PGM-FI Main Relay, or possibly repair it... http://www.tegger.com/hondafaq/mainrelay.html good luck. 94
Old Dec 8, 2009 | 04:13 AM
92hatch!'s Avatar
and then i woke up this morning...and the ****ing thing started....whats the deal...it just picks when it wants to start...****in gay
Old Dec 8, 2009 | 04:15 AM
92hatch!'s Avatar
thanks alot man i think this might help...your a life saver
Old Dec 8, 2009 | 04:18 AM
92hatch!'s Avatar
anyone else have any input im gonna work on it when i get home from school..so any help is much appreciated if anyone else has other ideas...thanks in advance
Old Dec 8, 2009 | 04:56 AM
92hatch!'s Avatar
also this morning when it did work...it hesitated.. and the check engine light like flickered..then it turned on...
Old Dec 8, 2009 | 06:58 AM
HondaPartsHero's Avatar
Technical Hero
For the heck of it check the ground on the thermostat housing, I believe that is where the main relay gets it's ground from
Old Dec 8, 2009 | 09:54 AM
92hatch!'s Avatar
ill do that^
bump
Old Dec 8, 2009 | 12:34 PM
92hatch!'s Avatar
bumpppp
Old Dec 8, 2009 | 12:38 PM
92hatch!'s Avatar
thermostat ground is fine ....the search continues lol
Old Dec 8, 2009 | 01:35 PM
92hatch!'s Avatar
bump
Old Dec 8, 2009 | 01:48 PM
92hatch!'s Avatar
ttt
Old Dec 8, 2009 | 03:22 PM
92hatch!'s Avatar
bump
Old Dec 8, 2009 | 09:18 PM
92hatch!'s Avatar
bump
Old Dec 8, 2009 | 09:32 PM
96Dc2 GSR's Avatar
try cleaning the thermostat housing where the ground goes, clean the bolt if its dirty or what ever if anything grab jumper cables...on one side put both ends on the negative and the other ends put one where the thermostat ground goes and the other one to the ground on the tranny...
its been happening to all my projects so far (fuel pump not priming) and thats all i do if not i hope i help'd
Old Dec 8, 2009 | 10:06 PM
92hatch!'s Avatar
you really think that would work?
Old Dec 9, 2009 | 07:53 AM
fcm's Avatar
fcm
Old Fart
Did you check any of the things I suggested?94
Old Dec 9, 2009 | 07:55 PM
92hatch!'s Avatar
^yep still no luck...bump this sucks...
