d16y7 crank position sensor question, please help
Old Dec 7, 2009 | 03:05 PM
tnxx's Avatar
Default d16y7 crank position sensor question, please help
My 98 civic original y7 just froze, I was wondering if I can use z6 or blocks that does not have the "crank position sensor" from 92-95 civic without throwing the code? Or that sensor has to be plugged in?
thanks
Old Dec 7, 2009 | 03:22 PM
Adriano's Avatar
Default Re: d16y7 crank position sensor question, please help
I beilieve the crank sensor is on the oil pump? You can just use a obd2 pump that has the sensor. Or just get a chipped ecu.
Adriano
Old Dec 7, 2009 | 03:29 PM
tnxx's Avatar
The motor locked up because or no oil. Not sure if the oil pump is still ok.
I'll check it out.
thanks.
Old Dec 7, 2009 | 03:49 PM
suspendedHatch's Avatar
Sensor plugs in near / behind the crank pulley, and yes you need that. There is a way to bypass it though.
Old Dec 7, 2009 | 05:43 PM
HondaPartsHero's Avatar
Technical Hero
http://www.ff-squad.com/technet/ckftrick.htm
twinj
10
Apr 19, 2007 07:18 AM
blowbyu24
Oct 24, 2005 09:53 AM
