Suspension & Brakes Theory, alignment, spring rates....
fastbrakes 11" rotor pics?
Old Dec 7, 2009 | 12:18 PM
hialeahzbg's Avatar
Default fastbrakes 11" rotor pics?
does anyone have any pics? is the difference huge compared to the stock gsr rotors?
Old Dec 8, 2009 | 04:48 AM
hialeahzbg's Avatar
Default Re: fastbrakes 11' rotor pics?
anyone?
Old Dec 8, 2009 | 08:32 PM
El_Capitan's Avatar
Originally Posted by hialeahzbg
anyone?
Message Clean Rice he has/had this setup, He might have picture or two...
Old Dec 9, 2009 | 04:51 AM
hialeahzbg's Avatar
any vendors here or anyone who actually works at FB? i wanna ask you guys a question...
Old Dec 9, 2009 | 12:03 PM
kommon_sense's Avatar
Can you be specific in regards to what you are trying to figure out and exactly which of their 11" rotors you are considering.
Old Dec 9, 2009 | 02:43 PM
89ssgti's Avatar
from left to right.
11.1 in. legend gs rotor
11.1 in. slotted itr rotor
11 in. corado rotor(fastbrake kit)
10.3 in. Integra rotor
9.5 in. Civic rotor
sorry didn't have a better picture
Old Dec 9, 2009 | 04:01 PM
Maluko's Avatar
that 10.3 inch rotor a gsr or ls ?
Old Dec 9, 2009 | 04:50 PM
roastbeefrichie's Avatar
90-93 integra & 94-01 integra all use 10.3" front rotors and same front brake calipers stamped 17cl14vn (regardless if it is a gsr or an ls)
Old Dec 9, 2009 | 05:44 PM
89ssgti's Avatar
exactly
Old Dec 9, 2009 | 08:51 PM
hialeahzbg's Avatar
I wanna see pics of the FastBrakes 11" kit with 15" wheels...
Old Dec 11, 2009 | 09:21 PM
dleccord's Avatar
wow why do legends have such big rotors?
Old Dec 11, 2009 | 09:52 PM
89ssgti's Avatar
because they are big cars I guess.The gs has almost the same front braking system of the first gen nsx
11. in fastbrake kit with 15 in dai fever wheel.(only pic I found)
Old Dec 12, 2009 | 03:40 PM
jr_deleon's Avatar
Thank you for stating this. I still cant believe people think the GSR has any different brakes than an LS/RS/GS.
Old Dec 12, 2009 | 06:50 PM
hialeahzbg's Avatar
Nice! I've tried calling FastBrakes not no luck...
Old Dec 14, 2009 | 08:27 PM
khaesaechao's Avatar
first time knowing gsr and ls same size
Old Dec 27, 2009 | 02:04 PM
moosh23's Avatar
New User
Originally Posted by 89ssgti
from left to right.
9.5 in. Civic rotor
Is the Corado rotor for a Corado, or is this the rotor that you get for a civic or teg if you order a fastbrakes 11" kit?
There seems to be no where near as much pad contact area on that rotor.
Old Dec 27, 2009 | 03:06 PM
Originally Posted by moosh23
1. Is the Corado rotor for a Corado,
2. or is this the rotor that you get for a civic or teg if you order a fastbrakes 11" kit?
1. yes, the corado rotor is for a corado.
2. if you look at the pic originally posted by 88ssgti, the 2nd rotor from the left (itr), best illustrates the 11" rotor fastbrakes.com offers. the prelude vtec 11" are the same size as well (they're hubcentric & readily available at parts store shelves, but need to be re-drilled to 4X100 while the fastbrakes.com rotor comes 4X100 already).
* both front rotors are 11"...but they're offsets are both completely different and are meant for different set-ups.
A. the "fast-brakes" style 11" front rotor is meant for milled brackets which allow you to swap:
integra type-r (stamped 17cl15vn),
nsx,
or legend gs 2-pot
front calipers using bigger knuckles (not small DX knuckles).
B. the 4X100 corado 11" front rotor is used on civic DX knuckles with s2000 & RSX front caliper brake upgrades (which seem similar to the calipers the mugen active gate offers). again, quick access to easy to find, pretty inexpensive, off-the-shelf parts readily available at any local parts store.
Old Dec 27, 2009 | 07:55 PM
rallypoint_1's Avatar
This is my setup. 90 STD hatch w/fastbrakes kit, VW Corrado rotors and DA calipers.
Stops really nice. Upgraded with a DA brakebooster, 15/16MC and 4040 prop valve.
Old Dec 27, 2009 | 09:13 PM
.dave's Avatar
i HAS questions ?
FastBrakes 11" kit with 15x7 TE37s
Old Dec 28, 2009 | 03:19 AM
Derek128's Avatar
i'm using 17CL15VN Integra Type R calipers,w/ 23T bracket GRINDED 3.2mm caliper mounting brackets ,with a redrilled Prelude VTEC rotors
will the corado rotor fit my set up?
the corado rotor's pads area seems like smaller than itr rotor
Derek128's Avatar
Old Dec 28, 2009 | 04:48 AM
Dogginator's Avatar
Daisy... Daisy...
I thought the Fastbrakes kit used a redrilled 92-96 Prelude VTEC rotors, which have the same dimensions are the ITR rotors with the exception of the 64mm center bore. I have two sitting in may garage and can check later. I do not recall them looking anything like the Corrado rotor pictured above. The ones on my car now were 92-96 Prelude VTEC rotors redrilled by a local machine shop.
Old Dec 28, 2009 | 07:35 AM
BigDare23's Avatar
More 11.1in brakes vs rims pics
11.1in verse 14in rims
11.1in verse 15in rims
Old Dec 28, 2009 | 08:15 AM
Dogginator's Avatar
Daisy... Daisy...
Originally Posted by BigDare23
That is definitely a redrilled 92-96 Prelude VTEC rotor.
Old Dec 28, 2009 | 02:29 PM
firstly, thanks to everyone for pix!
nice wheels
pimpin brakes
89ssgti, just wondering if you would happen to know what knuckle and caliper on this fastbrake.com 11" set-up?
rallypoint_1, nice brakes! what knuckle is this on? looks like it requires a hubcentric ring?
.dave, i has question? what calipers and knuckles? looks like integra front calipers (stamped 17cl14vn) on the fastbrakes.com adapter bracket, corado rotors on DX knuckles w/ hubcentric rings?
bigdare23, what caliper & knuckle are you using on this fastbrakes.com 11" rotor set-up?
dogginator's right, you're going to have to use a prelude vtec front rotor (re-drilled to 4X100) with any brake set-up associated with milled brackets stamped 23T, 25T & 28T for nsx calipers, legend gs 2-pot calipers or ITR calipers (stamped 17CL15VN). or you can buy em 4x100 from fastbrakes.com
* the VW rotors have a different offset. corado 11" rotors in 4X100 are brake caliper set-up specific. the pattern that's developing is the VW corado 11" rotor w/ a hubcentric ring & adapter for integra 17cl14vn front calipers on DX knuckles
according to the info on this thread, it appears the trend developing is that they're two different types of 11" rotors fastbrakes.com offers depending on caliper/knuckle set-up.
* the vw corado 11" rotor can also be used to convert 9.5" front brakes to 11" on DX knuckles using s2000 calipers and modified brackets.
google: "DIY: How to convert your 9.5" brakes to 11.0" brakes - S2000"
agreed...on milled brackets and ITR 17cl15vn front caliper, non-DX knuckle
kommon_sense and myself just wanted to know:
