How to fix codes 10, 19, 22
Old Dec 7, 2009 | 10:56 AM
Tru3nV's Avatar
Default How to fix codes 10, 19, 22
Hi,
I recently bought a 93 honda civic ex with a D16Y8 engine. I have been adding sensor plugs left and right because not everything was located on the harness. I have a few codes left that I cannot find the answer to. The ECU throws codes: 10, 19, and 22. Considering I know for a fact that the IAT is not on the y8 head, I know that needs to be installed, but where and how? Code 19, Automatic transmission lockup control valve. I dont have an automatic transmission. This code just leaves me scratching my head. Code 22, VTEC pressure valve. I dont know where the plug is for this sensor. I've looked everywhere, The IAT looks very similar, 2 pin, same fitting and everything. Do I have to directly wire this to my ecu?
Thanks
Old Dec 7, 2009 | 01:52 PM
Former User's Avatar
Default Re: How to fix codes 10, 19, 22
Code 19: You have an ECU for an automatic transmission but need one for a manual transmission.
Old Dec 7, 2009 | 02:00 PM
Tru3nV's Avatar
Thanks Ron,
I recently found this link.
http://www.hondacivicforum.com/forum...ad.php?t=65008
Conversion of the ECU to Manual.
Can anyone confirm this?
Old Dec 7, 2009 | 02:05 PM
Tru3nV's Avatar
Update
I installed the IAT directly to the air intake.
Haven't checked for codes again.
Will do tomorrow.
Old Dec 7, 2009 | 02:52 PM
Tru3nV's Avatar
Question, Since I have no plug for the Vtec pressure sensor, must I wire a plug directly to the shocktower and a ground?
Did some research and found this:
http://www.ff-squad.com/tech/wiring/...ktowerplug.jpg
Can I get someone to confirm this as well?
Old Dec 8, 2009 | 04:58 PM
Tru3nV's Avatar
All right.
So I fixed all the previous codes.
Now I'm getting CEL 7.
Throttle Position Sensor.
It wasn't showing before.
Anyone have a run through of how to go about troubleshooting this?
Also, When driving the car, acceleration is very poor.
Thanks
Old Dec 8, 2009 | 05:42 PM
supersize's Avatar
pull out the sensor and clean it, it may just be dirty or loose
Old Dec 8, 2009 | 06:04 PM
HondaPartsHero's Avatar
Technical Hero
http://hondaswap.com/general-tech-ma...sor-tps-58326/
Old Dec 10, 2009 | 09:17 AM
Tru3nV's Avatar
Much appreciated supersize and HondaPartsHero.
I have an OBD1 p28 that was made for automatic that I converted over to manual. With this ECU I get codes 4 and 7. I have a P06 from a 93 Civic DX. I know the P06 isn't equipped with VTEC settings, but with this ECU I get no CEL. I'm very confused. Is there any reasoning behind this?
Justin4
Engine Management and Tuning
Jan 29, 2010 08:14 PM
progress
Apr 14, 2005 01:09 PM
blackcruzan
Dec 10, 2003 09:30 AM
nomavtec
Jul 18, 2003 01:14 PM
whitebread_pothead
May 22, 2003 09:28 AM
