how to remove old head gasket & copper spray?
Old Dec 7, 2009 | 06:31 AM
Charlie Moua's Avatar
Default how to remove old head gasket & copper spray?
Whoever installed the headgasket last used copper spray or something close to it.
As I pulled off the gasket it ripped and came off in many part leaving a thick layer of the gasket material on the head.
I've tried using a fine kneif but did not help.
I didn't want to scrape it off with a lot of force or else it could leave marks on the head.
Q:
how do I remove old A6 paper style headgasket off head?
- aircraft stripper?
- just scrap it off and don't worry about scaring the head
- dremel with sanding wheel
Old Dec 7, 2009 | 04:27 PM
JOE BD-0's Avatar
Default Re: how to remove old head gasket & copper spray?
Q:
check out the video at the bottom of the Tyson crx/civic faq thread, you will find it there. I bought it from Grainger(sp?). good luck......
Old Dec 7, 2009 | 04:29 PM
jddwls's Avatar
3M makes some good abrasive pads that will not hurt the metal. their ring-loc system with a mild pad works like a champ! otherwise, walmart sell a generic orage/red scuff pad wheel, about 4" diameter that you can use with a drill. i went through 3 of them last time i did a HG. a mess to clean up, but did a phenomenal job!
Old Dec 7, 2009 | 06:12 PM
thanks guys....
y8 hg FTW...thats for sure...
Old Dec 8, 2009 | 12:05 AM
nitewolf's Avatar
gasket remover lol its like $4 something
Old Dec 8, 2009 | 09:59 AM
Clipsed's Avatar
send it to me I'll get that **** right off...
That's just after sitting in my tank.
Old Dec 8, 2009 | 10:38 AM
jddwls's Avatar
**** clipsed, if you werent all the way across the US, I got a few that need cleanin...
Old Dec 8, 2009 | 11:46 AM
Clipsed's Avatar
haha, everything is getting cleaned and rebuilt...
Old Dec 8, 2009 | 08:11 PM
Tyson's Avatar
im putting the video file in this thread. i dont like random videos in my faq list.
Removing Gaskets From Aluminum
Cho0se
Feb 24, 2020 02:59 PM
civicboy420
May 19, 2014 11:11 AM
hatchet_honda
Sep 10, 2010 05:17 AM
da_33
Jan 11, 2007 11:12 AM
