HELP B16A WONT START OR CRANK!!!!
Old Dec 6, 2009 | 09:14 PM
joexjoex44's Avatar
Icon3 HELP B16A WONT START OR CRANK!!!!
i replaced the starter with a new one. fuse is good. fuel pump is giving fuel to the motor. and when i go to turn the key all i here is the fuel pump click on like its suppose to. but when i turn the key to try and crank it. nothing, not a sound. no spinning, nothing.
Old Dec 7, 2009 | 03:19 AM
:::SIRll_EJ1:::'s Avatar
Default Re: HELP B16A WONT START OR CRANK!!!!
i would start by testing the main relay and grounds
Old Dec 7, 2009 | 04:42 AM
S_F's Avatar
S_F
Do you hear the relay click when you turn the key? If so, bridge the two poles on the starter solenoid with a screwdriver and then have someone else turn the key.
Old Dec 7, 2009 | 05:01 AM
91' LS-VTEC's Avatar
double check your wire that connects to the starter.
Old Dec 7, 2009 | 02:42 PM
joexjoex44's Avatar
grounds are good. wires are good. heard of anything like some sort of kill switch? it makes no clicking sound. not one sound at all
Old Dec 7, 2009 | 06:17 PM
FlatBlkEk's Avatar
Ive seen remanufactured starters not work.
Ive popped the 80 amp fuse before forgetting i didnt disconnect the battery.
Ive disconnected a cars battery with an alarm and had to find the little valet button
or switch so it will allow the car to be started.
Old Dec 7, 2009 | 08:41 PM
SingleCammer's Avatar
my civic wont start !!
i connected a TPS wire with
a IAC wire and now car isnt starting
Old Dec 7, 2009 | 09:28 PM
Former User's Avatar
OP: Check the starter switch located at the top of the clutch pedal.
Old Dec 10, 2009 | 02:52 PM
joexjoex44's Avatar
thanks for the help. any more ideas?
Old Dec 10, 2009 | 06:39 PM
-__-'s Avatar
wait what?
Old Dec 10, 2009 | 07:04 PM
Malfa's Avatar
mine wouldnt start either, did all that you had done. turned out it was my alarm..
took that out and it started fine
Old Dec 10, 2009 | 09:17 PM
mrharmonic's Avatar
what about the battrie? lol hey happoned to me lol just clicked but whont start unless the battrie was strong
killaberna
Sep 9, 2015 07:56 PM
99 SI TYPE R
Mar 11, 2014 05:44 AM
Fresh Ej2
26
Apr 2, 2009 06:19 PM
taboo948
May 19, 2008 07:26 AM
Black93EG
Apr 26, 2004 10:43 AM
