Remove Lower Radiator Hose/Thermostat
Old Dec 6, 2009 | 03:58 PM
guille595's Avatar
Default Remove Lower Radiator Hose/Thermostat
I am trying to replace my 1999 Accord's (4-cyl) thermostat and am having difficulty removing the clamp off of the lower radiator hose. I cannot get a pair of pliers, vice grips, or anything in there to loosen the clamp to pull the hose off. Any suggestions of how to do this? Should I remove objects in the way? Thanks.
Old Dec 6, 2009 | 04:18 PM
nus_dogg's Avatar
Default Re: Remove Lower Radiator Hose/Thermostat
Have you try a vice grip to clamp and keep it tight then pull the hose off?
Old Dec 6, 2009 | 05:09 PM
mavvrik's Avatar
I clearly says in his post he's already tried that.
If you really wanna get it off and never have to worry about it ever again, go to sears and buy the special clamp pliers for them. You will never struggle with another clamp like that ever again
thunderfck
Mar 9, 2013 09:48 AM
Nocturnal
Dec 1, 2005 11:58 AM
92 honda ex
Dec 3, 2004 01:51 PM
WRTEG
Apr 3, 2004 04:59 AM
goforbroke
Jan 21, 2003 07:59 AM
