need a help...bloggin when it drives on 1st gear...
Old Dec 6, 2009 | 03:56 PM
jdmISmyGOD's Avatar
Default need a help...bloggin when it drives on 1st gear...
wuts good, man....
i got eg bubble n its vx, obiviously its from canada...d15b8, i believe so...
so when i was driving and the car shows no much power...no pressure at all...when i put the first gear on and its like bloggin....and it goes really really really slowwwwwwwwwwww on rpm..even i installed brand new clutch...so lmk wuts wrong wit it, thanks...
btw, is it good to drive long distance with a bad dizzy ckp 4 code thrown? lmk, thanks..
Old Dec 6, 2009 | 05:01 PM
jdmISmyGOD's Avatar
Default Re: need a help...bloggin when it drives on 1st gear...
help me out, man..
Old Dec 8, 2009 | 07:42 AM
fly_high_gsr's Avatar
start with oem plug wires and cap and see how it feels. i had same issue sounded like misfire and i changed wires and prblem went away.
Old Dec 8, 2009 | 10:28 AM
jdmISmyGOD's Avatar
but it wasnt misfire..but yeah, the spark plugs is not all the same and the one of spark seem little burn to me but i sanded it little bit...but its like when ya go on first gear and it didnt give you much power to push...it takes forever to go on 3rpm to change the right mph, ya know..
Old Dec 8, 2009 | 12:02 PM
jdm inc's Avatar
have u check your timing?
Old Dec 9, 2009 | 09:31 AM
jdmISmyGOD's Avatar
the timing is fine when i started it...it starts right up...but when it moves n it feels no pressure at all....probablky the throttlebody gasket is leaking..or manifold...
BombayBeats
15
Sep 18, 2015 01:22 PM
blackeg
May 8, 2013 01:02 PM
Midori Green
15
Nov 3, 2007 05:16 PM
Takumi Fujiwara
Apr 12, 2005 03:03 PM
