Will this wheel/tire combination fit without rubbing?
Old Sep 2, 2002 | 12:20 PM
Tommy_Gunns's Avatar
Default Will this wheel/tire combination fit without rubbing?
15x7, +43 offset, 225 wide tires (possibly 50 or 45 aspect ratio)
Stock suspension, will this rub on the fender or tie rod?
[Modified by Tommy_Gunns, 3:20 PM 9/2/2002]
Old Sep 2, 2002 | 12:41 PM
Back in Black's Avatar
Rather OG
Default Re: Will this wheel/tire combination fit without rubbing? (Tommy_Gunns)
With 45 series, you MAY be able to get away with it. I ran them without spacers, but had stiffer suspension while doing so. With stock suspension, you'd most likely rub. 50 series will DEFINITELY rub.
Old Sep 2, 2002 | 11:06 PM
Default Re: Will this wheel/tire combination fit without rubbing? (Jason Franza)
Who makes 225/45/15 R compounds?
Old Sep 2, 2002 | 11:37 PM
Reid's Avatar
Global Moderator
Default Re: Will this wheel/tire combination fit without rubbing? (George Knighton)
Hoosier AS/RS303 and Kumho V700 Ecstas come in that size.
Old Sep 2, 2002 | 11:38 PM
Is the rubbing problem from the rear wheels or the front?
Old Sep 3, 2002 | 10:51 AM
ttt
Old Sep 3, 2002 | 11:02 AM
Reid's Avatar
Global Moderator
Odds are you're going to have to more problems with the rear tires rubbing on the rear trailing arms than with anything else.
I can't run 225s on stock wheels in the rear without rubbing. To prevent the rubbing I would need spacers which are leave the wheel studs with less engagement than I'd like.
Old Sep 11, 2002 | 06:02 AM
K's Avatar
K
New User
Default Re: Will this wheel/tire combination fit without rubbing? (Reid)
so 15x7 43 mm offset ... can run 225/45/15, but ONLY with spacers in the rear?
and with 205/50/15, the size and offset is perfect for ITR?
Old Sep 11, 2002 | 08:06 AM
H-PIMP's Avatar
Default Re: Will this wheel/tire combination fit without rubbing? (K)
Why do you guys insist on running pathfinder tires on an ITR? 195/55R15 is the PERFECT tire size for an ITR. No squirm, plenty of clearance, and, correct aspect ratio.
Old Sep 11, 2002 | 08:10 AM
jg's Avatar
jg
check this out: I'm in the same boat...
https://honda-tech.com/zerothread?id=265265
Old Sep 11, 2002 | 08:34 AM
K's Avatar
K
New User
Default Re: Will this wheel/tire combination fit without rubbing? (H-PIMP)
LOL, wht a statement .. 195 perfect size for ITR. why are u so ignorant? 205's are almost the MINIMUM width that u'll want on a track.
Cheers.
Old Sep 11, 2002 | 09:16 AM
Big Phat R's Avatar
With 43 mm offset I think you will be able to fit a 215/45 only - unless you roll your fenders the 50 series will rub (but it depends on the tire).
205/50 is the best choice for a 15x7 rim. It also offers better rim protection than a 195/55.
Old Sep 11, 2002 | 09:49 AM
1GreyTeg's Avatar
I run Hoosier's in 225/45/15 for autocross on 15/7" Volk TE37's and stock suspension. I do Not have any rubbing trouble in the rear, rather I do see some slight rubbing on the inside Front of the wheel well when the wheel is at full lock.
Remedy is try hard NOT to go full lock it's not the best way to turn and get any steering response as we already know And after spinning a few times last sunday I have some extreme personal experience with this.
There are many who run this combination and some who also stagger fronts 225/45 to rears 205/50. It depends on preference. I like a good slide like the rest of them but even sizing front to rear tends to keep the car handeling as neutral as possible without too much oversteer. I just play with the tire pressures to get it where it feels right.
Last week was best at F: 35psi and R: 33psi. the day was hot, about 90 and the track was rough, dirty and Hot. I started at 35 all around and felt that the rear was way too loose for my taste, I spun twice. I have run as high as F: 38 and R: 45 dependiong on the conditions and Temp.
Good luck, Ask whatever you like;
A.
Brandeezy1
Jun 20, 2012 04:04 PM
mrchris1979
Feb 3, 2008 12:15 PM
Utilitarian
Jun 21, 2005 07:49 AM
AamirCWITR
Aug 6, 2004 10:14 AM
Batoutahell
Oct 30, 2002 05:38 AM
