P2R thermal Throttle body power gain
Old Dec 4, 2009 | 05:34 PM
VTIargentina's Avatar
Default P2R thermal Throttle body power gain
Hi,
will I get any benefit at all by installing a P2R thermal gasket to the throttle body?
I also want to change my throttle body for an 62mm ITR
I have a B16a2.
should I also change the intake manifold?
or with just the throttle body I will see benefits?
Old Dec 5, 2009 | 09:00 AM
Mike95lude's Avatar
Default Re: P2R thermal Throttle body power gain
Originally Posted by VTIargentina
Hi,
I have a B16a2.
The P2R Throttle Body gasket is a waste of time in my opinion. Your best bet is to just get a thermal insulating gasket for the IM to the head. That is where the majority of heatsoak will be taking place. If you have one of those gaskets in place, your TB shouldn't be getting very hot.
If you have a stock B16A2 head (i.e. stock cams, etc.) then the stock throttle body should be just fine. If you're getting some larger cams, etc., then it would be worth considering.
Old Dec 6, 2009 | 07:59 AM
Terrible One's Avatar
what do you have done to your b16?
Old Dec 7, 2009 | 03:09 AM
hytech replica header 2.5 exhaust. FPR, VAFC2, AEM tru power pulleys ITR intake camshaft. AEM V2.
my idea was to get a b18 throttle body now (it is 62mm) and keep my oem Intake manifold, that is why I was thinking in getting this thermal gasket.
will I get any benefit at all?
PRIMITIVEALLMOTOR
Engine Management and Tuning
Aug 9, 2008 05:21 PM
jwamp316
Oct 26, 2005 01:49 PM
honda94civicturbo
Oct 14, 2004 12:58 PM
NirVTEC
Oct 11, 2003 05:39 PM
Y2K Si FBP
Oct 12, 2002 06:32 PM
