what injector size?
hi guys looking to get my car tuned as soon as i get a couple more parts... should i go with rc310s? or rc370s? heres my setup:
81.5mm b18c1
head milled .008
block decked .008 - not sure
usdm ITR pistons
micro polished crank
CTR intake cam
cam gears
pw jdm whale ***** intake
blox 68mm TB (port matched and tapered)
skunk2 pro series IM
hondata IM gasket
bennen fuel rail
kidd racing narrow header
test pipe
greddy sp2 catback
hondata s200
i think thats all...any advice or suggestions would be appreciated...looking to put down atleast 185whp....thanks
81.5mm b18c1
head milled .008
usdm ITR pistons
CTR intake cam
cam gears
hondata IM gasket
bennen fuel rail
test pipe
greddy sp2 catback
hondata s200
310's should work perfectly fine with your current set-up. If you are planning to go with much bigger HP goals than you should concider 370's.
I run RC 370's right now at 184whp in my GSR with ITR cams at 60% max duty. I have some more parts going on and expect to end up around 70-75% duty. In my set-up I'm using the stock fuel pressure regulator and stay below 80% max duty. But that's just me.
I would get the largest injector that doesn't impose a price increase. Since you are using Hondata, you will have no problem getting the car to run perfect with the higher flowing injectors. Additionally, it gives you more headroom for future modifications and if you ever need to sell them used, you'll have more buyers interested most likely.
i would have to agree with 94dc. the H22 injectors are more than enough for your setup. or go to xenocron.com and get some Precision injectors. there like almost $100 cheaper for the same size injectors as RC, and they work great
http://injectordynamics.com/
This post should explain the why.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/bosch-900cc-injectors-vs-rc-550cc-2687802/
thanks for the input....well because i found a used mint set of 310s & 370s for pretty cheap. i plan on eventually upgrading. i just wanted something that would benefit my setup for right now.
HATCHBACK GORILLA!
Oct 8, 2007 09:00 AM
B18cHatch06
Jan 29, 2005 11:05 AM
obd2gsr
Aug 21, 2004 10:14 AM
