So my gf hit a curb and.....
Old Dec 4, 2009 | 03:50 PM
hassan21's Avatar
Icon2 So my gf hit a curb and.....
she bent the rim.
also now the wheel seems to be pushed back a little because when u turn the wheel either way it seems that its rubbing slightly against the wheel well.
what do you think it could be?
Old Dec 4, 2009 | 03:53 PM
.Manny.'s Avatar
Touching My Member
Default Re: So my gf hit a curb and.....
you need to dump her.
get under the car and look. might just be an Lca
Old Dec 4, 2009 | 03:59 PM
hassan21's Avatar
what does LCA mean?
Old Dec 4, 2009 | 04:00 PM
dangthemang's Avatar
Lower Control Arm
Old Dec 4, 2009 | 04:03 PM
hassan21's Avatar
Alright how could i tell if thats bent or nething? cuz i looked at everything and i cant see anything bent or any stress marks on the parts
Old Dec 4, 2009 | 04:14 PM
BiG ChOr!Zo's Avatar
Originally Posted by dangthemang
Lower Control Arm
Old Dec 4, 2009 | 04:42 PM
hassan21's Avatar
any other help?
Old Dec 4, 2009 | 04:50 PM
prelude182's Avatar
youre better off taking it to a shop. get a steely to replace the rim and dont let her drive your car anymore
Old Dec 4, 2009 | 04:58 PM
NACvicSi's Avatar
I would have it put on a alignment machine. When I hit a curb to dodge a truck in my 91 hatch it ended up doing slight frame damage.
Old Dec 4, 2009 | 04:59 PM
elf469's Avatar
X2
Old Dec 4, 2009 | 06:16 PM
jbrokos307's Avatar
i had the same issue i had to replace my rear sub frame and my lcas and radius rod heres a pic of my lca lol
Old Dec 4, 2009 | 07:15 PM
jddwls's Avatar
been there done that ^^^ mine was a little less bent than that thought...
Old Dec 4, 2009 | 07:36 PM
hassan21's Avatar
would an alignment fix the problem?
because if i put the wheels straight you can see that the wheel seems pushed back
Old Dec 4, 2009 | 07:46 PM
thumper64's Avatar
An alignment won't help if something is bent. The best you could do is get the toe and camber correct and the caster way, way off. Something is bent, something has to be replaced.
Old Dec 4, 2009 | 07:49 PM
hassan21's Avatar
but how come when i looked at it nothing looked bent or had any stress marks on the metal
Old Dec 4, 2009 | 08:03 PM
jbrokos307's Avatar
pull ur wheel off something gotta be bent for your caster to be off mostlikely the lca mine happend making a slow u turn my car is dumped so u know it got fawked up what side is bent i have a extra driver side i didnt use that u can have for 30 plus shipping most likely she may have bent the inner tie rod also i just replaced everything
Old Dec 4, 2009 | 08:05 PM
hassan21's Avatar
i did pull off the wheel and looked at everything ill even take a pic if you would like me to....ive looked at everything that could be possibly it but i cant see it
if your on aim IM me on there.
Old Dec 4, 2009 | 08:17 PM
KINGVEM^^ED6's Avatar
Id shoot her lol
Old Dec 4, 2009 | 10:13 PM
backyard_concepts's Avatar
LMAO!
Old Dec 4, 2009 | 10:41 PM
NACvicSi's Avatar
Dude just take it to a shop to have them put it on a alignment/frame machine. They can tell you real quick if it is out of whack.
Old Dec 4, 2009 | 10:58 PM
t3601's Avatar
your awesome, that belongs on the trophy wall.
Old Dec 5, 2009 | 06:16 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This is because you OBVIOUSLY have NO CLUE what you are looking at...
Old Dec 5, 2009 | 07:46 AM
just-ef-it's Avatar
i had this happen to me, twice! once in july 08, once in july 09. ive become an expert on this situation lol
it all depends on how hard you hit the curb, in both my accidents, i had to replace both fenders cuz it pushed the wheel that far back, so i can say i hit them pretty hard lol
worst case scenario:
look at these parts mostly for damage, in both my cases, i just replaced all those parts in both my accidents
254899 001 001 BEAM, RR. (P.S.)
88572 001 001 SPRING, FR. STABILIZER
86510 005 002 ROD, FR. RADIUS
86511 006 001 ARM, R. FR. (LOWER)
86515 012 001 FORK, R. FR. SHOCK ABSORBER
61745 001 002 BEARING ASSY., FR. HUB (KOYO SEIKO)
86463 007 001 KNUCKLE, R. FR.
57288 010 002 JOINT, BALL (LOWER) (MUSASHI)
86858 025 001 END, R. TIE ROD
Old Dec 5, 2009 | 09:29 AM
gringo7718's Avatar
When you look at the lower control arm, there is a seam from the casting process that runs the length of the arm. This seam should be straight. You can use a string and pull it taught from end to end and see if it is bent.
When I hit a curb to doge an Excursion, I gunned it right before impact to shift the weight off of the front and luckily my car jumped the curb which limited the damage. I still replaced: front lower control arm, front upper control arm, knuckle/hub, radius rod, and shock fork. After an alignment I still have some caster issues but it is almost perfect. (I probably bent the rear subframe too)
Old Dec 5, 2009 | 10:14 AM
handicrx's Avatar
