d16z6 injectors getting no pulse
i have replaced the dizzy twice... but the fuel injectors still aren't getting pulse... its very confusing because the car will crank up every now and again... what could be the cause of this?
I'm not sure.. I've replaced the main relay twice.. replaced the dizzy twice.. but still cutting off after runs for a few minutes.. We're scratching our heads at this
How do you know the fuel injectors are the problem?
Check fuses 31, 24, and 18 (power for main relay).
Clean and tighten the ground on the thermostat housing (ground for ECU).
Make sure the ECU connectors are fully seated and that none of the terminals are bent or corroded.
I don't know that the fuel injectors are the problem.. Like I said we're scratching our heads at this.. thx for the tips Ron will check that out tomorow morning
tundra2000
Jun 16, 2010 08:46 AM
