Moms Car Wont Start
Old Dec 4, 2009 | 06:14 AM
Rickdogg's Avatar
Icon3 Moms Car Wont Start
i have been havning this problem wit my moms car every once and a while it wont start all the lights turn on just no crank i took the starter in had it tested they said it was good then i bought a new battery cause i found out that was one of the problems after i put a new battery in it worked for a while now it dont want to start again could it be the main relay? or the ignition switch? i called honda they said that the switch was already replaced someone help me pls
Old Dec 4, 2009 | 03:49 PM
Rickdogg's Avatar
Default Re: Moms Car Wont Start
bump
Old Dec 4, 2009 | 03:54 PM
accord99power's Avatar
are all belts turning including timing when cranking over? if no --->starter or battery If Yes---> do a fuel and spark test.
Old Dec 5, 2009 | 08:17 AM
Rickdogg's Avatar
it doesnt crank at all just a click but all the lights turn on
Old Dec 5, 2009 | 08:24 AM
redbull-1's Avatar
Did you get check the alternator? If the battery started it after you changed it, the alternator may not have been sufficiently charging the battery.
Try jump starting the car, if it starts, it may be the alternator.
Old Dec 7, 2009 | 10:21 AM
Rickdogg's Avatar
yeah i checked it out the alternator is still good
Old Dec 7, 2009 | 10:38 AM
TheMuffinMan's Avatar
He knows where you live!
Electrical portion of the ignition switch would be my vote
Old Dec 7, 2009 | 02:49 PM
alkoholikwun's Avatar
a few weeks ago my buddy had a bad starter in his DB. took it to autozone and it passed the test but still ended up being faulty. found one on craigslist for $30, works great.
Old Dec 9, 2009 | 01:38 PM
try a jump start with the terminals off the battery of another vehicle. Basically your running jumper cables to another cars battery. A completely bad battery will not crank over even with jumper cables. i suspect the starter as the main problem (get a hammer and beat on it a few times, See if it trys to crank after beating on it. Or check ignition key next.
ONISHIMA
Feb 7, 2007 09:03 PM
VisPreludeVtec
Dec 9, 2004 09:44 AM
95greenteg
Nov 29, 2004 02:56 PM
tan2
Nov 4, 2002 10:10 AM
