3" Cat?
Old Dec 4, 2009 | 05:10 AM
EdSales's Avatar
Default 3" Cat?
I'm going to get a 3" Downpipe for a Turbo I am putting together. I asume it won't just bolt on to my 2.5" Cat, so where do you find a good 3" Cat, or will the 3" Down Pipe plug into the 2.5" Cat?
Old Dec 4, 2009 | 11:19 AM
boxeocampeon's Avatar
Default Re: 3" Cat?
it will be able to bolt on if you get the right collectors or whatever their called. but just get a 3" cat by kamikaze or skunk2 theres a lot
Old Dec 4, 2009 | 02:00 PM
93egSLEEPER's Avatar
Default Re: 3" Cat?
dont cat a turbo motor.... there goes all your power. If you absolutely have to then yes get a 3". Best thing to do it find a test pipe.
Old Dec 4, 2009 | 04:39 PM
Default Re: 3" Cat?
hasnt there been studies out saying that there is not difference really between a high flow cat and a test pipe? im not sure tho
Old Dec 4, 2009 | 06:25 PM
joelmatt89's Avatar
Default Re: 3" Cat?
on stock motors it's very minimal i think less than 3hp if that. But on boosted cars it is pretty significant. Just google it and look for dyno charts you'll find plenty.
Old Dec 4, 2009 | 10:51 PM
Default Re: 3" Cat?
oh okay thanks
Old Dec 4, 2009 | 11:30 PM
backyard_concepts's Avatar
Default Re: 3" Cat?
good luck.
Old Dec 5, 2009 | 10:02 AM
Default Re: 3" Cat?
I havedone a personal study, had a cat and dyno'd at 298whp on 10psi. got my testpipe put on and re-dyno'd at 308whp same 10psi.
Old Dec 5, 2009 | 02:02 PM
Del Namco Solo's Avatar
Default Re: 3" Cat?
you are right. The difference between a high flow catalytic converter and an open pipe is insanely less then comparing a straight pip to a stock catalytic converter.
I have a high flow catalytic converter, and it runs just as good as my friends car (same motor and upgrade parts) except he has a open test pipe.
Also, 3" isn't as cracked up as everyone thinks. Sure, it will help the turbo spool faster, but then ask yourself, why are you buying such a big turbo in the first place? You can get a tiny evo turbo and have it produce just as much power as a bigger turbo. I would go for a small turbo, which will already without a 3" exhaust, spool around 1500-2500rpm and you can keep a smaller exhaust.
When you do things right without cutting corners or buying things that are ridiculous, you can get a nice car going. For example, same motor, 2 different turbo's. Guy bought a GT60 garret turbo, other guy got a garret GT35 and was able to get exactly the same hp turnout as the other guy. Its pointless to go crazy with parts just to "look cool".
Get a little evo turbo or a t3/t4 hybrid with a 2.5 exhuast. You will make as much power as anyone else as long as you have the same upgrades (internals, build, port and polish, or other such parts)
Good luck with your car.
Boostage
Jul 1, 2005 11:20 AM
blu2ksi
Jan 15, 2004 12:57 PM
Anubyss
Aug 2, 2002 09:49 PM
KooK
Jun 25, 2002 10:03 PM
ezark
Jun 21, 2002 10:12 AM
