JRSC for k20. Cheap! $1800 obo
Old Dec 4, 2009 | 05:06 AM
crdizzle6288's Avatar
Default JRSC for k20. Cheap! $1800 obo
Ok guys so i have a jrsc i need to sell. Will come with 9 lb and 11 lb pulleys. I have a 3 pulley setup on my car now so i have a belt for it but if you have all the accessories still(ac or ps) you will need a longer belt. i have the original belt that came with it which is alot bigger. i have the jrsc power card still which i never used. the original owner used it but not very long. If needed, i will give an 05 k20z1 map sensor which reads a little higher thant he stock one. It will read up to 10.5 psi. JRSC has only been on my car a few months. Driven it maybe 10 times. Id say about 1500 miles tops on it including the original owners miles on it. Here is the link to my photobucket for pics.
http://s749.photobucket.com/albums/xx136/mhermsen1/
Old Dec 6, 2009 | 10:31 AM
92EGK20's Avatar
Default Re: JRSC for k20. Cheap! $1800 obo
Does it come with everything?
Old Dec 6, 2009 | 05:01 PM
yes it does. what do you consider everything? just so there is no misunderstanding.
Old Dec 6, 2009 | 05:41 PM
92EGK20's Avatar
Everything needed to mount it and in running order, minus injectors...
Old Dec 6, 2009 | 07:32 PM
ya everything you need to install. my friend wants his 9 lb pulley back so it will come with oem jackson racing 7 lb pulley and the 11 lb pulley. you reuse your bolts from your intake mani to bolt it up. the belt might need to be sourced depending on your pulley setup and if you have ac,ps,ep3 idle pulley etc. i will give you the power card as well.
Old Dec 7, 2009 | 05:23 AM
pm me its easier to talk that way.
nicotine
Jun 6, 2011 01:21 PM
crdizzle6288
Dec 8, 2009 11:30 AM
proton
Dec 27, 2008 08:44 AM
1sikhatch
Mar 13, 2007 04:57 AM
M-Type
Feb 16, 2003 07:56 PM
