Integra and civic brakes interchangable?
I have a 93 eg hatch with what i was told is a 94 integra ls front and rear disk brake swap. First how do i make sure the swap is from a 94 ls so i can buy correct brake parts/rims. and are civic brakes and integra brakes interchangable? i was looking at a wilwood front brake kit, but dont want them to end up not fitting because the guy i bought these brakes from lied to me...
bonus question: do integras and civics have the same bolt pattern?
1. I have a 93 eg hatch with what i was told is a 94 integra ls front and rear disk brake swap. First how do i make sure the swap is from a 94 ls so i can buy correct brake parts/rims.
2. and are civic brakes and integra brakes interchangable?
3. i was looking at a wilwood front brake kit, but dont want them to end up not fitting because the guy i bought these brakes from lied to me...
4. bonus question: do integras and civics have the same bolt pattern?
1. take off the front wheel, and inspect your brake set-up you currently have. integra front brake calipers are stamped 17cl14vn & uses a 10.3" front rotor.
2. no, the calipers do not interchange w/o the use of an additional bracket (ie., aem, fastbrakes, etc)
3. what did he lie to you about?
4. yes, the bolts, mounting points and bolt-patterns are the same; but if you tried putting a civic caliper on a teg knuckle or teg caliper on a civic DX knuckle, they would physically fit but it just won't work because you would have offset & cearance problems with your rotors.
* if you're shopping for wilwoods, buy a set which would work for civic ex, 99-00 civic si or 94-00 integra if you have 94-00 integra knuckles on your 93 civic eg hatch.
Sorry i wrote that confusing, i didnt mean he DID lie to me. Just that IF he did, i dont want to be up ***** creek with the wrong kit.
Thank you for all the info tho, il post up what i find later
streethondar
Jan 13, 2011 05:49 AM
