Misfired Cylinders...I Need Help Fixing It
Old Dec 3, 2009 | 11:22 PM
luis83190's Avatar
New User
Default Misfired Cylinders...I Need Help Fixing It
I have a prelude 1999 and the check engine light popped out
Checked it and it has 2 misfired cylinders
anyone have any idea how to fix this?
Please HELP!!!
Old Dec 4, 2009 | 05:12 AM
young_tuner's Avatar
Default Re: Misfired Cylinders...I Need Help Fixing It
check your ignition coil, mine has a hairline crack and is causing mine.
Old Dec 4, 2009 | 09:34 AM
prelude1897's Avatar
when was the last time you changed your plugs, cap, and rotor?
Old Dec 4, 2009 | 07:22 PM
stakskits's Avatar
Had the same problem now fixed...Misfires can be due to a number of problems. check out
https://honda-tech.com/forums/honda-prelude-4/p0300-p0301-p0303-cylinder-misfire-help-2688151/
Old Dec 4, 2009 | 10:01 PM
5spd5gen's Avatar
start out with plugs wires cap and rotor, if that doesnt work, then move to your EGR, if thats not it go to your injectors.
best of luck fixing your problem
Old Dec 5, 2009 | 11:17 PM
luis83190's Avatar
New User
The spark plugs are new and the cap I just changed it rotor havent touched it
Old Dec 6, 2009 | 06:14 AM
Here are things to look for when having that misfire code
* Ignition System
* Fuel Supply System
* EGR System
* IAC Valve
* Contaminated Fuel
* Lack of Fuel
* Valve Clearance
* Fuel Injector Circuit
* Low Compression
hondaaccordf23
Mar 5, 2012 09:37 PM
jeremyyeahh
Apr 12, 2009 06:02 PM
RomoGuy
Apr 11, 2005 03:12 PM
asiansgoweeee
Jul 14, 2004 08:26 AM
CIVIC dude
Sep 13, 2003 01:27 PM
