d16z6 turbo build
Old Dec 3, 2009 | 03:43 PM
zachsboostedD's Avatar
Default d16z6 turbo build
ok heres my d16z6 turbo build...but i need some info about the vitara pistons...should i get them or get a set of CP's....how long do vitaras last...
my hp goal is 400+....just give me some info about a good build for 400+hp...its going to be a daily driven car...
75mm vitara pistons/w FJ h-beam rods/or 75mm cp's with eagles
king bearings
comp cam 59300
supertech valves springs
supertech valves (STD)
oem retainers
Supertech bronze valve guides
mild port
performer x manifold
68mm throttle body
1000cc injectors
p28 ecu w/hondata s300
hondata 4 bar map
golden eagle fuel rail
golden eagle cam gear
si trans
obx lsd
comp stage 4 sprung clutch
stock flywheel
turbo
garrett t3/to4e ar.60/.82 60trim
tail wastegate
hks ssq bov
twisted ramhorn manifold
30.5x11.75x3 intercooler
3inch downpipe
3inch exhaust
Old Dec 3, 2009 | 03:59 PM
FullRacePhil's Avatar
Default Re: d16z6 turbo build
i would check out http://www.d-series.org/forums/ for more info on the vitara pistons, and i would recommend the eagle rods if you can afford them.
Old Dec 3, 2009 | 04:10 PM
yea im going to do eagles i done made my mind up....
Old Dec 3, 2009 | 04:30 PM
ndondahows's Avatar
Honestly, there are a few vitara setups out there that make 400+ but i would say the majority don't if you are talkin a pump gas tune...I think where you will get the most benefit and make it easier to attain your power goals you will need a very good flowing head..But, on pump again, expect 350-375.
Old Dec 3, 2009 | 04:42 PM
yea, but i heard they dont last very long 5k miles at the most....yea i going to do it on pump gas...i would be happy with 375hp..but i know some people that has 400+ on pump gas...it is all in the tune...if you have a good tuner then your going to expect some good numbers...
Old Dec 4, 2009 | 06:46 PM
bunnyx's Avatar
What? vitara pistons only last around 5k? thats not good news for me. i was planning on doing the same set-up but i guess not anymore because i need a car that would last long and still have at least 350hp.
Old Dec 5, 2009 | 05:19 AM
yea i think the most their getting out of them are like 8k....they will hold 400+hp but just not for very long...its because of the piston to wall clearance is not right and its beating the rings and pistons to death....but if you want to bore your block to 75.5mm and get the piston to wall clearance right then you should be alright if you have a good tuner...im still doing the vitara setup with 75mm...im goin to see what it does at 400+ daily driven....
Old Dec 5, 2009 | 07:22 AM
BoostedEgHatchFl's Avatar
Thats bs, theres people around me at have well over 20k on there vitara motor and still running strong.
Old Dec 5, 2009 | 08:28 AM
man thats dam good....i was just reading about them and they said they dont last long around 5 to 8k...i was just taking there word for it...because i know some people thats only got 4k out of theirs and then had to get their block resleeved because of the piston slap it beat the **** out of there walls and it lost compression... but if you know some people thats getting 20k out of them thats great man...im defiantly doing it now...i just ordered them with the fj h-beam rods....
Old Dec 5, 2009 | 08:38 AM
boostedEF91's Avatar
i've had 20k plus on my old vitara build. pump gas the whole time.. they will last.. you wont be disappointed man.. cant always go off what other people say..
Old Dec 5, 2009 | 08:42 AM
man thats good....i hope it will...yea true...
Old Dec 5, 2009 | 08:51 AM
what would be a good turbo for my build....i was going to get the t3/to4e .60/.82 60trim..but i dont know yet...i like to have it start spoolin around 3800 to 4200rpms and carry out to redline...
Old Dec 5, 2009 | 03:16 PM
Go-autoworks.com has a really nice 50 trim. Its made by Borg Warner and its a custom spec built turbo just for the d series motor. Thats he turbo my dad has on his built vitara motor, but we haven't drove the car with the new turbo on yet.
Old Dec 5, 2009 | 03:23 PM
Terrible One's Avatar
vitara/eagle will make around 7.4:1 compression in a d16z6. this will work but isn't ideal cause combustion is not happening at the right place. fj distributors make custom length i-beam rods that will make 8.4:1 compression with the vitaras. they also claim their rods can handle 500+ whp.
i recommend a t3/t04e 57/60 trim or t3/60-1
Old Dec 5, 2009 | 03:31 PM
T3 60-1 one will be way to laggy, go with the proven turbo that works. Go-autoworks has alot of info on it.
Old Dec 5, 2009 | 04:22 PM
i done made my mind up im getting a t3/t04e 60trim...i did some reading about it on a vitara setup and it does what i want...it sarts spoolin around 4400 rpms and carrys out to redline...i thank that i will be a good turbo for my setup...
Old Dec 5, 2009 | 04:32 PM
You wont hit full boost will 5500-6000
Old Dec 5, 2009 | 04:59 PM
I really hope you dont plan on running a .82ar 60 trim..... I'll have a brand new 57 trim in 2 or 3 weeks for sale.
Old Dec 5, 2009 | 06:56 PM
no if i get the .82 its going to be the 50 or 57 trim
Old Dec 6, 2009 | 01:56 AM
Thats going to be super laggy man....
Old Dec 6, 2009 | 05:47 AM
dont get the .82, go with a 57trim in a 63ex. i had the bulleseye 57 with a 70 ex. was a lil laggy but worked very well.. i hope you plan on revin to at least 8500 if you get a 82.
Old Dec 6, 2009 | 05:49 AM
had a friend stock y8 only had pistons/rods.. made 340 on 20psi with a garret t3/t4 57trim 63ex. and 385 on 25psi.. turbo carried hp very nicely to 7500
Old Dec 6, 2009 | 07:37 AM
yea its going to be revved to 9500....so what turbo would you recommend a t3/to4e 60/.63 57trim
Old Dec 6, 2009 | 09:18 AM
Yea a .63 ar will still hold all the way up there, but you will get better spool. Like I said, I will have a brand new 57 trim in a few weeks. I'm getting a brand new AFI kit and we'll be upgrading to a bigger turbo. So your your going to a 57 trim I can give you a deal on one.
Old Dec 6, 2009 | 09:33 AM
ok just let me know..i might get that off you if i have the money...if you incinerated in doin a trade that would better...i have a nitrous setup that i be willing to trade...comes with a 10lb bottle never had nitrous in it, a set of cold fusion pro solenoids, 1 20inch -4an line,2 12inch -3an to -4an line,and a nozzle...its worth 500 brand new...
