d16z6 turbo build
ok heres my d16z6 turbo build...but i need some info about the vitara pistons...should i get them or get a set of CP's....how long do vitaras last...
my hp goal is 400+....just give me some info about a good build for 400+hp...its going to be a daily driven car... 75mm vitara pistons/w FJ h-beam rods/or 75mm cp's with eagles king bearings comp cam 59300 supertech valves springs supertech valves (STD) oem retainers Supertech bronze valve guides mild port performer x manifold 68mm throttle body 1000cc injectors p28 ecu w/hondata s300 hondata 4 bar map golden eagle fuel rail golden eagle cam gear si trans obx lsd comp stage 4 sprung clutch stock flywheel turbo garrett t3/to4e ar.60/.82 60trim tail wastegate hks ssq bov twisted ramhorn manifold 30.5x11.75x3 intercooler 3inch downpipe 3inch exhaust |
Re: d16z6 turbo build
i would check out http://www.d-series.org/forums/ for more info on the vitara pistons, and i would recommend the eagle rods if you can afford them.
Originally Posted by FullRacePhil
(Post 40836209)
Honestly, there are a few vitara setups out there that make 400+ but i would say the majority don't if you are talkin a pump gas tune...I think where you will get the most benefit and make it easier to attain your power goals you will need a very good flowing head..But, on pump again, expect 350-375.
Originally Posted by ndondahows
(Post 40836557)
yea, but i heard they dont last very long 5k miles at the most....yea i going to do it on pump gas...i would be happy with 375hp..but i know some people that has 400+ on pump gas...it is all in the tune...if you have a good tuner then your going to expect some good numbers... |
What? vitara pistons only last around 5k? thats not good news for me. i was planning on doing the same set-up but i guess not anymore because i need a car that would last long and still have at least 350hp.
Originally Posted by bunnyx
(Post 40848487)
Thats bs, theres people around me at have well over 20k on there vitara motor and still running strong.
Originally Posted by BoostedEgHatchFl
(Post 40851485)
i've had 20k plus on my old vitara build. pump gas the whole time.. they will last.. you wont be disappointed man.. cant always go off what other people say..
Originally Posted by boostedEF91
(Post 40851972)
what would be a good turbo for my build....i was going to get the t3/to4e .60/.82 60trim..but i dont know yet...i like to have it start spoolin around 3800 to 4200rpms and carry out to redline...
Go-autoworks.com has a really nice 50 trim. Its made by Borg Warner and its a custom spec built turbo just for the d series motor. Thats he turbo my dad has on his built vitara motor, but we haven't drove the car with the new turbo on yet.
vitara/eagle will make around 7.4:1 compression in a d16z6. this will work but isn't ideal cause combustion is not happening at the right place. fj distributors make custom length i-beam rods that will make 8.4:1 compression with the vitaras. they also claim their rods can handle 500+ whp.
i recommend a t3/t04e 57/60 trim or t3/60-1 |
T3 60-1 one will be way to laggy, go with the proven turbo that works. Go-autoworks has alot of info on it.
i done made my mind up im getting a t3/t04e 60trim...i did some reading about it on a vitara setup and it does what i want...it sarts spoolin around 4400 rpms and carrys out to redline...i thank that i will be a good turbo for my setup...
You wont hit full boost will 5500-6000
I really hope you dont plan on running a .82ar 60 trim..... I'll have a brand new 57 trim in 2 or 3 weeks for sale.
(Post 40855909)
Thats going to be super laggy man....
dont get the .82, go with a 57trim in a 63ex. i had the bulleseye 57 with a 70 ex. was a lil laggy but worked very well.. i hope you plan on revin to at least 8500 if you get a 82.
had a friend stock y8 only had pistons/rods.. made 340 on 20psi with a garret t3/t4 57trim 63ex. and 385 on 25psi.. turbo carried hp very nicely to 7500
yea its going to be revved to 9500....so what turbo would you recommend a t3/to4e 60/.63 57trim
Yea a .63 ar will still hold all the way up there, but you will get better spool. Like I said, I will have a brand new 57 trim in a few weeks. I'm getting a brand new AFI kit and we'll be upgrading to a bigger turbo. So your your going to a 57 trim I can give you a deal on one.
(Post 40860500)
