axle
i just wanna make sure when i replace this axle on my car on the pass side that im supposed to use a 90-93 integra? Its a 90 si hb with a zc and stock breaks? i know there is a seal that i need to look for but i cant figure out how to tell if i have the seal for the integra axles or not. Im kinda confused on this i just need a straight answer on this so i can get the part asap
doesn't matter as much what engine it is, it matters what transmission it is.
But if it's a zc then you aren't using a 90-93 integra axle. That's what is used for b-series swaps.
First, what transmission do you have?
besides, they don't need to be 90 si axles, any non abs d16/d15 axle if work.
