B-series ITR swap - fresh rebuild, Exedy, Findanza, CTR, Hondata, P28, etc
SOLD! SOLD! SOLD!
I've got a '96-spec ITR swap for sale in Alabama. The head was freshly rebuilt in the spring and it only has 2,000 miles on the motor since reassembling it.
All gaskets have been replaced, new head gasket, timing belt maintenance, etc.
This sale is just for the motor/trans/linkage/ecu.
Also has all sensors and a new IACV.
It DOES NOT come with the header in the picture.
Price -SOLD!
96 spec ITR swap, freshly rebuilt stock - All Honda parts
New valve seals
3-angle valve job
All new gaskets
New OEM headgasket
New timing belt, tensioner
New water pump
New distributor
New NGK plugs and wires
Hondata IM gasket
Polished 00 SI fuel rail
OBD2 injectors
96-spec ITR LSD trans - perfect, no grinds (stamp came off while cleaning )
Exedy Racing Stg 2 clutch
Fidanza 7.5-lb flywheel
CTR N1 crank pulley
P28 tuned w/Crome
MFactory magnetic oil pan and trans drain plugs
ITR "gold" shift linkage
ITR shifter
ES Shifter bushings
No name VTEC solenoid cover
JDM ITR oil cap
Will throw in the Mugen shift **** attached to shift linkages for free.
PLEASE BUMP IF YOU VIEW.
Thanks!
Price -SOLD!
New valve seals
3-angle valve job
All new gaskets
New OEM headgasket
New water pump
New distributor
Hondata IM gasket
OBD2 injectors
CTR N1 crank pulley
P28 tuned w/Crome
ITR shifter
ES Shifter bushings
JDM ITR oil cap
Thanks!
Thanks guys, appreciate the comments. Yeah it is a good deal, hate that I have to get rid of it.
TTT! Someone please get this. I can arrange for shipping but you will have to pay for it. I can deliver it up to a couple of hours away, but you will have to pay for fuel costs. Send me offers!
