H22 top end build
Old Dec 2, 2009 | 05:05 PM
carlitosway12345678's Avatar
Icon2 H22 top end build
I drive a 97 base model lude, and i picked up a JDM head for dirt cheap with the intention to shave it, throw in some cams, and performance valve train. now the question is what to get for it. Any ideas?
I will probably be getting my block sleeved, new pistons, whole deal when i swap in the built head.
So my question is, what do you guys recommend for a N/A daily driver build?
Old Dec 2, 2009 | 06:45 PM
ilikehonda's Avatar
Default Re: H22 top end build
first and foremost send it to a reputable shop! look to sig for my opinion
Old Dec 2, 2009 | 07:08 PM
Enzo15's Avatar
Not to threadjack, but is it possible to raise the redline just by using performance springs, and retainers? Im assuming it would be ok because the springs would keep the valves from floating at the higher rpm.
Old Dec 2, 2009 | 07:46 PM
q16racer's Avatar
you would need an engine management system to raise the fuel cut. It takes a good bit of RPM to make even the stock heads float valves without it being driver error.
OP, Dont machine the head unless it requires some to be removed to make it flat. When you remove material, thats it. There is no going back and it can seriously put a bump in your road depending on the type of build you want to do. If you want to raise the compression, do it with either a thinner gasket or by building the bottom end to be a higher compression.
________
Mercedes-benz a-class
Old Dec 3, 2009 | 01:45 AM
mmm.. well where this head is a spare one, im not worried too much about there being no going back. Anyway, what do you guys recommend for parts? what are you guys packing in your cars?
Old Dec 3, 2009 | 07:55 AM
ilikehonda's Avatar
ive got s2 valvetrain, s2p1 cams, s2 pro series cam gears, stainless flat valves......
Old Dec 3, 2009 | 03:39 PM
q16racer's Avatar
not anything for the street
________
Amc Spirit Specifications
Old Dec 4, 2009 | 03:20 AM
Hahaha.. Thanks :p
Old Dec 4, 2009 | 07:27 PM
HdeucedeuceA's Avatar
Check out the dyno thread in the all motor section for some idea's. I'm personally gonna be running Skunk2 Pro 1's with supertech valveterain.
Old Dec 4, 2009 | 07:34 PM
SergEK's Avatar
If you are gonna build a motor I would check out NAH2B's setup with a little less comp for street use and maybe using pro 2's.....pro 3's may be okay
I would also look into building a big stroker motor with a larger F series block
The main thing on my mind --- your trans/gears holding up to 260-300whp NA =(
CA121
Dec 27, 2010 01:28 PM
efchris
Mar 8, 2009 02:39 PM
kelvinchau25
Aug 25, 2005 07:22 AM
civproject14
Jun 28, 2005 12:15 PM
topsekret
May 12, 2005 09:47 AM
