Lude is stuck in gear
Old Dec 2, 2009 | 05:00 PM
vosoka's Avatar
New User
Default Lude is stuck in gear
Need some help
It seems as my lude is stuck in one gear. I depress the cluch to start her up and its not untill i let it go that the car stalls out. seems like shifting it does nothing, and sometimes the shifter gets stuck untill i have someone roll forward and then i can move the shifter once again. Any ideas...
h22a4/ m2y4 / 5speed
Thanks in Advance.
Old Dec 2, 2009 | 05:10 PM
Boost_Addict_88's Avatar
Default Re: Lude is stuck in gear
It sounds like either your transmission or clutch is going.
Old Dec 2, 2009 | 05:20 PM
carlitosway12345678's Avatar
something loose in the transmission. You say its only when you drop the clutch it stalls? sounds like a tranny problem..
Old Dec 2, 2009 | 05:27 PM
+1.
Pull it out and take it apart to see if you notice anything obvious. If you're not comfortable with it, have a friend that knows transmissions to help you out. Maybe you can learn something new. ^_^
Old Dec 2, 2009 | 05:38 PM
AndyD's Avatar
I bought an Accord 2 months ago with almost exactly what you describe. I was hoping it was a clutch issue, but when I drained the oil from the tranny, or should I say lack of oil, I realized it was a problem with the tranny, not the clutch.
Try this. Check your tranny fluid level first.
Old Dec 2, 2009 | 06:20 PM
vosoka's Avatar
New User
Oh man, alright well ill pull Her out Open Her up and take a look Inside.
Thanks everyone
Old Dec 2, 2009 | 08:37 PM
kornkid21792's Avatar
aaaaaaaaaaaallllllso check your master cylinder and slave cylinder cuz when that happend to me it was because my slave cylinder crapped out
Old Dec 2, 2009 | 08:44 PM
vosoka's Avatar
New User
Had a friend press the clutch pedal and it seemed fine, is that a good way to test it?
Old Dec 3, 2009 | 06:49 AM
Rosko's Avatar
Go grab the shifters on the tranny itself and move them around. Maybe you just have a bad shifter cable or something, or something is in its way.
Old Dec 3, 2009 | 09:57 PM
Make sure your tranny-to-motor bolts are torqued to spec. My buddy had this issue in his Eclipse just today. The gears would grind when he'd downshift and get stuck. When he pressed the clutch, the transmission would seperate from the motor literally. Tightening those bolts fixed the issue. Also, check for clutch drag.
+1 on master cylinder.
Old Dec 3, 2009 | 10:53 PM
shakehand's Avatar
New User
no it wouldnt be a hydraulic problem, when my master cyl went out and i had little to nopressure in it, i could get it to disengage if i pumpped it alot, but i was able to shift with out clutching, quite easy really, just a last resort thing. so its not hydralui, check your linkage
Old Dec 4, 2009 | 10:09 PM
H22SHtec's Avatar
i had what sounds like the same problem. took my atts out and the transmission off to find out that one of the springs on the factory clutch disc popted out of the disc and was causing the throw out bearing not to engage evenly.
hope this helps
Old Dec 13, 2009 | 12:39 PM
Je2RiT's Avatar
last time i had this problem it was a bad syncro.
I took the tranny off and replaced the syncro and hadnt had the same problem.
unknownally
Transmission & Drivetrain
11
Jul 24, 2010 03:20 AM
dohcdelsol
Jan 7, 2005 10:11 PM
92 civic VX B18c
Oct 6, 2003 10:14 PM
Lo-Buck EF
Apr 28, 2003 06:56 PM
D15VTEC
Mar 19, 2003 05:17 AM
