Honda S2000 Honda S2000
S2000 power door locks??!!
Old Dec 2, 2009 | 04:44 PM
97eksoldier's Avatar
Icon2 S2000 power door locks??!!
hey guys sorry but i'm new to the s2k. my brother just got one and we noticed we could not find a button on the door panel for the power locks? is there even a button in the car? is it only the remote and manuelly unlocking it? thanks guys..i serached but couldn't find what i was looking for
Old Dec 2, 2009 | 05:05 PM
SirStig's Avatar
Default Re: S2000 power door locks??!!
I haven't seen one. Annoying as hell
Old Dec 2, 2009 | 05:29 PM
JDM JON's Avatar
me niether, im beggining to think we dont have one..lol
Old Dec 2, 2009 | 05:30 PM
TANGO28's Avatar
I hate it too! I have a 5 point harness and when im strapped in and my girl want to get in when the car is on i have to unbuckle and reach over just to unlock the door...
Old Dec 2, 2009 | 06:16 PM
bigmacnfries's Avatar
mine's got one.. just in front of the door pull handle. push in to lock both, pull back to unlock both.
are ours different to yours? or is it different depending on the year?? crazy...
Old Dec 2, 2009 | 06:51 PM
bky's Avatar
bky
Just take the key out of the ignition and use the remote.
Old Dec 3, 2009 | 03:56 AM
HondaKyle's Avatar
I can put my hole hand on top of the other door while sitting in my seat with out moving over... Its nice
Old Dec 3, 2009 | 04:09 AM
White Smoke's Avatar
i my honda
Global Mod
There isn't one... It's very easy to add a switch though, if you like.
Old Dec 3, 2009 | 04:40 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
fawking go-go-gadget arm...
Old Dec 3, 2009 | 08:33 AM
SirStig's Avatar
WHAT!! gotta go try after class
I hate shutting off the car. wastes gas and charge
I'm jealous lol
Is there a kit out there?
I need one of those too! :D
Old Dec 3, 2009 | 08:43 AM
i my honda
Global Mod
Not that I know of. All you have to do is tap into the factory alarm (not really an alarm) wiring. 2 wires is all it takes...
Old Dec 3, 2009 | 08:57 AM
ITRbroham's Avatar
shit post warrior
I'm barely 6 feet tall and can still reach over and unlock the passenger door.
Old Dec 3, 2009 | 09:52 AM
TANGO28's Avatar
yeah thats what ive been doing wish there was an easier way.
how did you add the switch? and were did you mount the toggle switch?
Old Dec 3, 2009 | 10:06 AM
TANGO28's Avatar
Lol ahhaha i wish...
Old Dec 3, 2009 | 10:21 AM
Memo6453's Avatar
ye i looked everywhere and gave up...glad to hear it doesnt come with one...lol
finding the release to re fuel was a mystery for me as well until this morning...lol
god im a noob
Old Dec 3, 2009 | 11:15 AM
both sides of mine have a central lock/unlock - so that makes me even more JDM - right?
the fuel release is a bitch - got me too..
Old Dec 3, 2009 | 12:08 PM
SirStig's Avatar
Got a quick step by step? I suck at wiring.
Haha I was a noob and went a googled it. Made money off my sister betting she wouldn't find it tho
Old Dec 3, 2009 | 12:25 PM
Driven's Avatar
to the OP. no, no button to unlock all doors... except the keyfob.
I think someone has a mod that does it, but forgot how it works.
try hooking it up to a switch in the glove box?
Old Dec 3, 2009 | 04:26 PM
esean93's Avatar
why do you guys have to argue so much online and have so much hostility?we are all s2000ers here.
id really like a switch to unlock the doors though,it makes the car look not so well thought out.z4s have it on the center console!isnt that fancy!haha
Old Dec 7, 2009 | 10:13 AM
i my honda
Global Mod
Originally Posted by modifry website
Passenger Door unlock info -
I've uploaded the installation manual for my ancient "convenience module" (which I no longer sell) for those that have asked for information on wiring a switch to unlock the passenger door. Look at page 4 in this manual and pay attention to the photo and instructions for wiring to the white wire (pin 3) of connector C502. This wire is attached to the driver's door key cylinder, and if you ground it for 2-3 seconds it will unlock the passenger door, just like if you hold the driver's door key in the unlock position for 2-3 seconds. Bear in mind it will only unlock the passenger door if the driver's door is already unlocked.
This same white wire is also available on the keyless entry module which is under the driver's dash, sort of behind the radio dash controls. It's a black box with an 18-pin connector (8 wires in one row, 10 wires in the other). Be careful, there are two white wires in this connector and one of them is +12v power, so accidentally grounding the wrong white wire is a bad idea. The white wire you want is near the middle of the connector and is between a black/white wire and a yellow wire. The white wire on the end of the connector is +12v power, stay away from that one.
Here's 2 more ways to unlock the passenger door
1 - The Keyless entry module has two pins for receiving lock/unlock commands from the security module. A ground on these wires will lock or unlock both doors. If you have factory security there are wires attached to these pins so you can tap into the wires. Pin 11 (grn/red) is unlock; Pin 12 (blk/wht) is lock. But if you don't have factory security there are no wires - just pins sticking out of the Keyless module and only accessible if you unplug the connector. You can either solder wires to the pins and run them out the empty holes in the connector or take the Keyless entry module apart and solder wires direct to the PC board where these pins connect. Not very friendly but it works.
OR
2 - Locate the Keyless Entry Module and connect BOTH door locks to the output for the driver's door. Then every time you unlock the driver's door with the remote, the passenger door will unlock too. The Keyless module is under the driver's dash, sort of behind the radio dash controls. It's a black box with an 18-pin connector (8 wires in one row, 10 wires in the other). Locate the pink/blue wire (passenger door lock) and cut it about 1" away from the Keyless Module. Insulate the end that goes into the module. Now locate the driver's door lock wire, which is either yellow/green or yellow/white depending on whether you have the factory security system or not. Make sure you do not get a plain yellow wire. You need to "T-tap" the free end of the pink/blue into the driver's lock wire. Once this is done, unlocking the driver's door with the remote will unlock the passenger lock too, since they are now tied together.
Want to get fancy?
It would be relatively simple to install a relay behind the passenger dash cover and wire it to the ROOF switch and run a wire to the Keyless module. The ROOF switch provides +12v, so if you wire it to activate a relay and then wire the relay contacts to ground the appropriate wire on the Keyless module you can unlock the door by pressing the ROOF switch. Cool. No extra switches to install. Of course the door will unlock any time you use the ROOF switch to operate the top, but you probably don't care.
http://www.modifry.com/freebies/door_unlock.htm
Old Dec 7, 2009 | 03:47 PM
vtec95's Avatar
Either use your key fob..and if you dont have one, you can get one on ebay for $7.00..just make sure its from an s2000..or....like stated before..pull the inside door handle and push your lock inwards to lock the car or outwards to unlock..or put the key in the outside lock and turn either left or right and hold it and it will lock and unlock both doors Thats what i did until i got my key fob.
Old Dec 7, 2009 | 09:46 PM
SirStig's Avatar
Thanks White Smoke. I tried the pushing and pulling of the lock on the driver side, it definitely only locks the passenger side but won't unlock it.. lame. Gonna try the wiring once it warms up, it was 7 degrees today...
Old Dec 7, 2009 | 11:06 PM
would anyone like pictures of mine?
Old Dec 8, 2009 | 02:56 AM
punchdrunk's Avatar
+1
Mine's a UK car though so I guess it's superior to the USDM cars.
Old Dec 9, 2009 | 04:27 PM
esean93's Avatar
great info white smoke!!!
